- Jan 15, 2015
I hope you got good memory, then...I have been without the FH5 for a week so all comparisons will be from memory
Do any of you use the official FiiO forums for discussion? I tried signing up once and gave up. For starters, the signup was insecure (http, not https), and I couldn't find much evidence that there was any real forum activity to begin with. I'm just wondering if I missed something.
The only option is buffersize samples. I have it set to 512 samples. I have no idea if that's where it should be or not lol.Look into the buffer settings that the FiiO control center is using. Try changing it to something like reliable. It may not be a factor, but it is easy to check and might very well be the issue. I had problems with clicks and pops with my Q5s as a DAC with JRiver Media Center 24 and once I played around with the buffer settings (also adjusted the buffer setting in JRiver to 25miliseconds) everything was fine. Hope that helps.
But it's also saying ASIO is not active.
Not sure, but on my PC in the tray I open the FiiO Control Panel and I see a tab for Buffer Settings.The only option is buffersize samples. I have it set to 512 samples. I have no idea if that's where it should be or not lol.
Hi,
which charger do you use to charge your M11?
regards,
Simon
An old Sony 5V 2A usb plug from a phone
Can I use power bank for charging? The power bank has 2 outputs...5V 2.1A and 5V 1A...
I selected HWA under settings on the fiio app. When I play songs back the song will play for a brief time then I hear nothing. The HWA is displayed in the upper right hand corner when a song is playing. If it displays LDAC, then I have no problem. MY question is do I need to adjust another setting when HWA is selected.
How would I knowAre the item us are bluetoothing too/from HWA compliant?
How would I know
