This is a picture. Found on the Internet, looks very good on the main screen)**** is that an album cover, or just a pic? I love it for a lock screen!
[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
Yes that's very tight, tight like a tiger as Goldmember would say.
Jujoe
Juj
In general, I will hope that in the new firmware the developers will fix everything. (I mean the interface, everything was fine, for what these changes were) Golden rule: When everything is good - no need to change anything!
cristox
- Jun 6, 2008
Welcome to opposite chinese thinking...
fatmanny
Yes but that's not how businesses work. If companies always stayed stagnant, they'd be just that: stagnant. As frustrating as change is to us as consumers, I understand how necessary it is from the business side of things. I absolutely hate it when Facebook changes the layout! But I got used to it.In general, I will hope that in the new firmware the developers will fix everything. (I mean the interface, everything was fine, for what these changes were) Golden rule: When everything is good - no need to change anything!
fatmanny
Hey, page 306. That's my area code. Neat.
BadReligionPunk
We will be at mine within a day or two. Especially with all these chatty Cathie's in here. :laugh:Hey, page 306. That's my area code. Neat.
RikudouGoku
Member of the Trade: RikuBuds
Since Quick Charge Generates more heat, doesnt using a charger without help the battery more?There is no memory effect. So you won't lose any cycles or life by partially charging it. In fact with these types of cells they recommend you don't let the battery go flat to increase battery life. And better to not let it at 100% for days- if you aren't going to use them for a while you should partially discharge them to the reccomend voltage or there abouts. Following these rules will get you the most use cycles.
I general recharge mine at 20% and then use my dap shortly after charging to bring the battery down. Or you can charge it to 90%
This info is from the manufacturers and rc hobbyists, which use a ton of li poly cells.
abitdeef
- Oct 30, 2003
Not usually recommended, yes it shortens the life a bit more.
brintamatic
- Jan 21, 2017
How can I connect my iPhone XS Max to the M11 through USB?
Jujoe
Sorry dont use apple Iphone but this might be the cable to connect one to the other.
https://www.amazon.co.uk/Apple-Original-Lightning-Charge-PACKAGING/dp/B01DGDNLYY
Hope it helps
Juj
I do not think. Pure Music mode does not kill the background processes of the Androyd, so the power consumption will most likely be identical. For example, owning an x5-3 device, there was no difference in battery consumption in the Pure Music mode and Androyd.
I figured that would be the case. I'm fine with how long the battery last even with the gain on high using balanced.
Speaking of balanced my 4.4mm cable for my HP-3 and Elear will be here tomorrow so I'm looking forward to that. I think the HP-3 will sound really good since it's very easy to driver but even the Elear at 80ohm and 104dB sensitivity to won't be to bad either.
I was kind of surprised just how powerful the amp is. I didn't know if the 550mW at 32ohm would be enough for my Sendy Aiva but it's plenty. On high gain I go between 60 and 65 on the volume and that's as loud as I can go before it starts to be to much.
Ulrich B.
Hello FiiO Support,
Thanks for the Update.
For me is the App Drawer Not so important.
For the pure music mode, is it posible you bring a option, that i can use Internet radio with the Fiio music app.
That's for me more important. Whitout a mode of internet Radio, makes the pure music mode not sence for me.
Please bring this feature by the next update.
Thanks.
Thanks.
kgs51
- Oct 30, 2015
I just received my M11 today. I put an external card in too. However, when I hookup my M11 to my pc, the pc doesn't recognize the external drive when I plug in my usb. As a result, I can not input song files in the M11 external drive. Anyone have any ideas. Thanks
Total: 11 (members: 0, guests: 11)
