[FiiO KB1K]FiiO Multimedia Keypad KB1K Is Officially Released!
Jan 8, 2024 at 3:38 PM Post #46 of 56
More investigations with tihs problem:
Easy to identify this problem, when you rotate a volume knob from click to click it work fine, but when you will rotate it from click to not click and let it go in half between clicks, then it will itself increase volume to max or decrease to min itself.
Strange behaviour, without fixing it's useless for multimedia.
Jan 8, 2024 at 10:49 PM Post #47 of 56
Thanks, right I fixed it, I have select some certifcates from site and this was cause a problem, solution is to Cancel any certificates and site is load fine.
@FiiO - after upgrade a firmware on website jadeaudio.com now my volume sometimes increase or decrease itself to maximum or minimum when move volume knob!
For example I rotate volume knob for volume up, left knob and volume goes itself goes up to maximum. This happen sometimes.
Before there was no problem like this ! This happen after upgrade firmware for sure. I quess your hold button function in latest firmware some mess here.
Please FIX THIS fast, now this device is useless
Dear friend,
We have reported to the engineer for check. Since they haven't reproduce the issue and did not find the regularity, it may take some time for us to fix the problem.
Best regards
Jan 9, 2024 at 5:11 AM Post #48 of 56
Dear friend,
Best regards
Great thank you, waiting for solution, without solution fix try to use it at night :)
By the way, is it possible that firmware to KB1 was badly flashed via jade.audio website ? Or it's not possible if device work fine exept this strange volume behavior.
Another question, for what this KB1 have Bluetooth and 2.4GHz options in settings ? does it mean it has built in Bluetooth comunication ?
EDIT:
Wow, you fixed this in today firmware update, RESPECT to FiiO engineers team and thank you veeery much!!! Now I'm happy with this device.
Jan 10, 2024 at 5:18 AM Post #49 of 56
EDIT:
Dear friend,
The KB1K does not have Bluetooth function. Yes, the problem has been solved now.
Best regards
Jan 11, 2024 at 3:35 PM Post #50 of 56
@FiiO - would be great and if it possible to make in future option to turn off lighting when computer goes to S3 Sleep State (my Razer Huntsman V2 RGB keyboard turn off lighting in S3 Sleep state)
I make option to turn off light like you showed in previous post SW on Mute button, but not perfect solution (lost Mute button)
__
Another request in future to sell aditional Media keycaps buttons with Play/Pause, Next, Prev signs on keycaps.
Maybe someone know where I can buy keycaps like this?
Jan 16, 2024 at 10:11 PM Post #51 of 56
__
Dear friend,
Hi, thanks for the kind feedback. We have reported to the engineer for assessing about that first.
Best regards
Jan 29, 2024 at 3:57 AM Post #53 of 56
Feb 25, 2024 at 7:22 PM Post #54 of 56
Hi Fiio,
I use one of the buttons to mute my microphone. Is there any way to program the lights to switch between just two colors, to instantly see microphone status?
I haven't yet found a "Color Table" that uses only two colors.
Another question I have, and I can't seem to find any documentation for this, is how do you use the "User Scripts"?
Thank you in advance!
Really happy with the product.
Feb 25, 2024 at 9:47 PM Post #55 of 56
Hi Fiio,
Dear friend,
You may check whether the FAQ could helps: https://www.jadeaudio.com/details?article_id=118&_l=en
Best regards
Jul 28, 2024 at 7:20 AM Post #56 of 56
I don't know if I am seeing things, but it looks like the LED lights below the 3 keys seem to be all of a sudden faded and slightly green-ish. I used to keep the lights always on - not sure what's the expected lifespan of the LEDs?
