[FiiO KB1K]FiiO Multimedia Keypad KB1K Is Officially Released!
May 16, 2023 at 11:06 PM Post #32 of 56
How does it look like in real life ???
Jul 23, 2023 at 1:41 AM Post #34 of 56
Dear friend,
The engineer help to test and find it could work:
His setting:
Best regards
I finally picked up one of these and it has exceeded my expectations. It works with MusicBee universally in Windows 10 even when the application is in exclusive mode! None of my keyboards could do this universally (only when MusicBee was the active window).
@FiiO can you provide some more details on the specific settings needed to be able to use the control knob for fast forward and rewind? Hopefully in English as I do not understand the settings in the image above. Thanks!
Jul 23, 2023 at 9:09 PM Post #35 of 56
Dear friend,
Can the fast forward and rewind control of the APP be adjusted by '<-' and '->' buttons? If yes, you could set like that:
If not, you could check which button can control and set the correct button in KB1K for help.
Best regards
Aug 8, 2023 at 3:29 AM Post #37 of 56
lol it's always fun when 2 of my hobbies merge together.
Need FiiO gaming mouse later LOL.
It says ESS dac chip, does it have a built in dac and can be used as stand alone dongle?
Good idea , this would be a pretty cool form factor for a mini desktop dac/amp- kind of like an apogee groove with clicky transport controls.
Audio gear with keyboard keys has a good history.
Sep 27, 2023 at 5:04 AM Post #38 of 56
The new firmware for KB1/KB1K is now available!​
Firmware download link: Click here
How to upgrade the KB1/KB1K(Firmware update is supported in Windows computer):
1.Unzip the firmware package. Run the 'upgrade' programme to start the upgrade;
2. When the message 'The firmware is up-to-date' shows, the firmware has been upgrade successfully and we could exit the upgrade programme.
Nov 20, 2023 at 9:11 AM Post #39 of 56
Nobody is probably going to want to try using the volume for a driving game on PC but I tried it anyways.
Doesn't really work for that purpose unfortunately 😂 the volume wheel doesn't recognize the A/D or Left/Right keys when turning the volume wheel left and right
Nov 20, 2023 at 10:29 AM Post #40 of 56
LOL I think it might be adjusting volume on the hardware level on the unit itself, and not providing feedback to the PC maybe?
Good attempt, A+ for effort. :thumbsup:
Dec 19, 2023 at 2:31 AM Post #42 of 56
@FiiO - why KB1 aluminium is not available on Alliexpress ?
Also, can you make keycaps with signs Play/Pause, Previous, Next.
Dear friend,
The KB1 has been discontinued and may no longer be sold.
Regarding the keycaps, I will forward your opinions to the engineers and they will analyze and evaluate them!
Best regards
Jan 8, 2024 at 1:15 PM Post #44 of 56
Yeah great move FiiO, you discontinued better much premium produckt and now produce only plastic cheap light version :clap:
One more thing this site do not work anymore, now https://keyboard.jadeaudio.com/device
403 - Forbidden: Access denied.​
You do not have permission to view this directory or page using the credentials you supplied.​
The site works for me here in the US
Jan 8, 2024 at 1:41 PM Post #45 of 56
Thanks, right I fixed it, I have select some certifcates from site and this was cause a problem, solution is to Cancel any certificates and site is load fine.
@FiiO - after upgrade a firmware on website jadeaudio.com now my volume sometimes increase or decrease itself to maximum or minimum when move volume knob!
For example I rotate volume knob for volume up, left knob and volume goes itself goes up to maximum. This happen sometimes.
Before there was no problem like this ! This happen after upgrade firmware for sure. I quess your hold button function in latest firmware some mess here.
Please FIX THIS fast, now this device is useless
