Dimitry188
Unfortunately, Fiio K9 Pro's capabilities are not enough to provide the right sound with Arya headphones.Guys, hi.
I'm still confused why my K9 PRO ESS sounds with my Arya V3 Stealth, AKxEE Odyssey, CA Solaris 2020, etc. pretty MEDIOCRE. Connection is only 4.4 balanced.
No, I definitely don’t have any technical problems or defects. Just the sound from k9 pro is at the level of pocket dongles for $200-300. But this shouldn’t be the case; the difference should be noticeable by ear. I'm using a phone and a type c input, maybe this is the problem?
The output mode is bitperfect, I'm sure of it, because during MQA output the ring glows purple.
Any ideas? Should I try playing with filters on K9, or will they not change the picture either?
These are very high-level headphones, they need a sound source of the appropriate level.
Which K9 Pro is NOT.
Especially at low frequencies.
Even Hifiman Serenade does not reveal all the possibilities of Arya.
An amplifier Aune S17 Pro is very good for Arya.
And to it - some kind of DAC of a sufficiently high level.
Only then can you hear all the possibilities of these headphones. It's almost a top.
Or you can connect an additional amplifier to your K9 Pro. For example, Singxer SA-1. The sound will get much better.
