bassman12345
I don’t. I have USB in, and RCA to powered speakers.Is it normal to hear a click just after turning on the K7?
I have the K7, but researched both. The iFi has a bass-boost, but I don’t think the iFi DAC is as good.Hello! Have any of you tested both the K7 and the iFi Zen Dac V2? I'm looking to buy a a DAC/AMP with a warm, musical and fun sound signature. I'm not really an audiophile, so i dislike neutral/bright sound. Thanks in advance!
Have you ever used Equalizer APO with the K7? If that's the case, how does it react to a bit more bass?I have the K7, but researched both. The iFi has a bass-boost, but I don’t think the iFi DAC is as good.
Negative. I use Boom 3D, which I got when I was using the onboard laptop DAC. Very useful for that, but with the K7 and the subwoofer in my Aiwa Axios-9 powered speakers, I have EQ off and just use the compressor (“night mode”) when watching movies or podcasts with the volume all over the place.Have you ever used Equalizer APO with the K7? If that's the case, how does it react to a bit more bass?
Warm/musical sounds like the Zen DAC v2 - though the Fiio K7 is certainly not clinical/shrill/super bright either.Hello! Have any of you tested both the K7 and the iFi Zen Dac V2? I'm looking to buy a a DAC/AMP with a warm, musical and fun sound signature. I'm not really an audiophile, so i dislike neutral/bright sound. Thanks in advance!
BTW, Windows has a “loudness” setting buried in the sounds settings usually, depending on your onboard DAC.Have you ever used Equalizer APO with the K7? If that's the case, how does it react to a bit more bass?
Thanks a lot! I was worried that the K7 would be too clinical, because according to a few reviewers THX amps sound a bit dry.Negative. I use Boom 3D, which I got when I was using the onboard laptop DAC. Very useful for that, but with the K7 and the subwoofer in my Aiwa Axios-9 powered speakers, I have EQ off and just use the compressor (“night mode”) when watching movies or podcasts with the volume all over the place.
Plenty of bass for me; and as an ex-bass player, I do like my bass!
That's exactly what i read on Reddit. The K7 is a good choice then. Thanks for your help.Warm/musical sounds like the Zen DAC v2 - though the Fiio K7 is certainly not clinical/shrill/super bright either.
Think of it this way - the warmest and bassiest of the lot Zen DAC v2 with bassboost on, then the K7, then Zen DAC v2 with bassboost off.
The K7 is sorta the inbetween of zen dac's bassboost on/off tonally, but the ifi zen dac is also quite underpowered even for an all-in-one. For your current and planned gear it'll be fine but if you ever plan on getting something harder to power down the line the zen dac may not cut it, increasing cost of ownership because you'd need to stack it with the zen can.
I'll say that both are absolutely fantastic devices
I've read quite a few reviews about The K7 and i think no one mentioned that. Maybe i just missed it because English is not my first language.If you read the FiiO literature for the K7, K9, and K9 Pro, you will see that the THX amps FiiO uses are not the standard off the shelf ones. FiiO worked with THX to make some changes to the THX amp they use and it sounds better than the standard ones. Don't worry about a 'dry' sound with the FiiO amps.
One click as you turn it on right? Yep sounds normal to meIt happens when I turn the unit on using the volume button. After 2-3 seconds of turning it on there is an audible click inside the unit, like something is turning on.
@FiiO is this normal?
Yes as you turn it on the button clicks and after that something inside the device clicksOne click as you turn it on right? Yep sounds normal to me
yeah sounds normal to meYes as you turn it on the button clicks and after that something inside the device clicks
This is normal operation. What you are hearing is the relay switch for your particular input being "engaged/activated".It happens when I turn the unit on using the volume button. After 2-3 seconds of turning it on there is an audible click inside the unit, like something is turning on.
