I'm also rocking the K5 Pro with Fidelio X2 and I'm very satisfied, hard to find a combo for similar price that gives such nice pack of features and audio quality.
Indeed a good bargain!
Does that caution still apply even if the speakers are switched off (while still connected via RCA )?
Hi,Hello
I have attached a pair of active speakers ( Edifier 350D ) to my k5 pro Dac+Amp.
The manual cautions that headphones must be disconnected while the k5 pro is connected via RCA to speakers.
Currently, I switch off the speakers while connecting my headphones to the k5 pro (so that I won't have to keep connecting/disconnecting the RCA cables )
What that means is that both the RCA and 6.35mm headphone jack will sound at the same time,Hello
Thank you very much for your support!That’s cleared one issue. Thanks
Another one though : I keep the volume dial on the k5 Pro all the way up and use the digital volume control in windows 10 desktop to set the desired volume. That’s an ok practice too, yes ? (Don’t want to reach all the way over to the device to adjust volume)
last one : when are you releasing the k9 pro ? I want that to drive my hd800s !!
