KaiFi
Whoa, closed-back headphones coming from Fiio? This is getting exciting ![Grin :grin: :grin:](https://cdn.head-fi.org/e/people/grin.svg)
Dear friend,Just curous to folks that own the FT3, how many use the swede pads?
also @FiiO just curous is there a reason why the lether pads arent distributed with vendor demo units? Seems to cut out a good amount of folks that are chasing a tighter dryer sound.
Also with reguards to the pads will the FT1 and FT5 be using the same pads as the FT3?
Dear friend,There've been rumors that a FiiO closed back headphone is coming... I think it's been referred to as the FT1. Is the Jade Audio JT1 that headphone, or is the FT1 on its way too?
Any frequency response chart that we can see for JT1 yet?Dear friend,
Thanks for your attention. The Jade Audio JT1 is coming soon(https://www.aliexpress.com/item/1005006176969361.html):
But FT1 is no futher information currently.
Best regards
The drivers on the FT5 are much larger. I would assume the pads are larger too.Was there ever a solution for the small earpads? They are just a little too snug on my ears to the point that they bother me.
Are the pads on the FT5 larger? Thanks.
Hmmmm. $636.00 in Canadian dollars, plus tax. The before tax price is pretty appealing. Hmmmm.90mm Open Planar Magnetic Headphones FT5 Is Officially Released!
Discover micron-level manufacturing and technology
The all-new FT5 is FIIO’s first planar magnetic headphones. Planar magnetic drivers are in between dynamic and electrostatic headphones. Like dynamic headphones, there is a sort of coil on the planar driver. Similar to electrostatic headphones, the diaphragm is a special kind of thin, micron-level film. The FT5 is 28nm chip-scale processed, leading to an approximately 6μm thick diaphragm. These characteristics of the planar driver make it possible to create a headphone that is not only highly detailed, but also easy to power.
Large 90mm planar magnetic driver
The FIIO FT5 employs an outstanding large 90mm planar magnetic driver. Compared to a traditional dynamic driver, a planar magnetic driver converts sound energy to sound waves in a more balanced way, by vibrating in a much more even way. The vibrations are distributed across the entire driver diaphragm and there is little distortion caused by the rigidity of the diaphragm material. Thus, the FIIO FT5 can truly and accurately express audio signals.
Micron-plated aluminum-silver alloy coils
During the development of the FT5, the R&D engineers not only needed to consider how the coils would interact with the 6μm thin diaphragm, but also the density and conductivity of the coils themselves. Having examined and tested various commonly-used materials* to plate planar coils, FIIO engineers determined that the lighter aluminum alloy material was best for the coils. Also, they determined that mixing in silver metal would also enhance conductivity of the coils, making the driver easier to power without sacrificing the high-frequency detail and rich sound characteristic of good planar magnetic drivers.
High sensitivity and easy to power
The FT5’s driver is both light and strong, allowing for a high sensitivity of 110dB/1Vrms@1kHz i.e. 96dB/mW@1kHz. This allows the FT5 to be easily driven even by portable players.
392 wires of high-purity silver-plated monocrystalline copper cable
The FT5 comes with a 1.5m cable made of 392 wires of silver-plated monocrystalline copper, each wire with a diameter of 23AWG. The copper wires help to give a solid and highly-detailed sound, fully transmitting lossless sound directly to you.
Abundant accessories
· 3.5mm/4.4mm interchangeable plugs
· 6.35mm male to 3.5mm female adapter
· XLR-4 male to 4.4mm female balanced adapter
· Suede earpads
· Protein leather earpads
· Leather storage case
* The FT5 is available on our AliExpress Official Store. Any order will be included with a headphone stand as a gift. Click the link below to take it home right away:
https://www.aliexpress.us/item/3256805990705530.html
Best regards,
Guangzhou FIIO Electronics Technology Co., Ltd.
Dear friend,Was there ever a solution for the small earpads? They are just a little too snug on my ears to the point that they bother me.
Dear friend,Any frequency response chart that we can see for JT1 yet?
HiFi Over-Ear Headphones JT1 Is Officially Released!
Small money for a big sound
“On the products we want to make, we want to focus more on the core needs of listeners – with less focus on appearance items and more focus on acoustic components such as driver units. We do not want to compromise – let listeners get a good-sounding headphone at a great price that lowers the barrier to getting HiFi sound.”
—— Vincent
Product Manager![]()
Focus on sound quality
The JT1 employs a 50mm dynamic driver, based around a PEK+PU+aluminum polymer diaphragm carefully chosen after evaluating numerous materials. The lightweight nature of the driver allows it to move quickly to reproduce even the most subtle of details, while being supported by a brass gasket means it also achieves low distortion and well-extended frequency response.
Easy to drive, for handy great sound
The JT1 is equipped with high performance N52 magnets, a high-tension CCAW voice coil, and a carefully-designed driver diaphragm in order to achieve a natural and accurate sound.
* Any order will be included with a balanced cable LL- 4.4A as a gift. Click the link below to take it home right away: https://www.aliexpress.us/item/3256805990654609.html
Best regards,
