FiiO-Yellow
Sponsor: FiiO
FH19 review by Gizaudio.
It's true that FH19 nozzles are different from FH9, FH19 nozzles can change the sound more.The time has come, after my 3rd listening session earlier in the office. Upper mids are way too hot to my taste with the green stock nozzle.
But then I went to the kit and noticed they're not the same as the FH9:
Has FiiO really changed those nozzles, or the kit on my unit got somehow sabotaged in production? Anyway, needless to say that I installed the bass nozzle from the FH9 and will leave it like that for a couple of days. At least now I can crank the volume while keeping the upper mids under control.
Nozzles: FH9 (left) vs FH19 (right). Top: bass/red; bottom: balanced/black.
If the set of filters on FH19 really corresponds to the image above, it would be good to have a measurement with legacy FH9 filters/nozzles. I am pretty sure K-Poppers will call this muddy.![]()
Historically, the FH was the fun series while the FA was the technical series.So FH19 is the fun& technical iem in the fiio lineup.
I'm waiting for a FH17. A hybrid with the same FH7 13.6mm berillyum/b.plated DD for that fast and textured bass . A FH7 with a more refined and extended treble basically .
It would be a great complementary iem for the FH19 that would be more clarity&detail focused .... potentially my endgame.
Yeah! That could be good. 4EST+2BA+large berillyum/magnalium DD.Probably meant FX17
That might be the first ever IEM that does not have insane timbre issues while using EST drivers.Yeah! That could be good. 4EST+2BA+large berillyum/magnalium DD.
Mixed bag, vs the FH9 (really a GREAT product of it's own)..."Are you wondering if the FH19 is an upgrade compared to the FH9? The answer is yes. Although the upgrade is not night and day, the gains FH19 provides are not to be trifled with. In terms of sound stage magnitude, mid-range tonality and overall coherency, the FH19 exceeds the FH9.
I still think the bass of the FH9 is more enjoyable and airier in the sub-bass region, but the FH19 provides better imaging overall. In terms of design? Well, that is subjective, but I find the FH9 more authentic and cooler."
FH19 VS FH9, from headfonia. https://www.headfonia.com/fiio-fh19-review/
Cons:
- Mid-bass can be congested and overly full
Except fun. UTWS5 are the only ones (in the BT IEMs world), as far as I know while searcing, with Low Latency, and they're ideal for watching movies!Now, this is fun...![]()
... FH19 nozzles can change the sound more.
