MrJudasPriest
Use the bass filter to dampen down any excess treble - works a treat to my ears.
I like polite treble too, sometimes too much so as I still have Fearless Roland in my rotation.Thanks. Any suggestion for an alternative IEM?
Any suggestion for budge full copper cable to warm FH7 a little bit?
I haven't tried any other cable, but you can try the orange filter, or use Sony o Final E tips to give body, bass and reduce some treble.
I love the FH7 with Final E, but I use the black default filter.
I use the FH7's with the FIIO balanced cable, Hiby R6 Pro, bass tips and bass filters, listen to Tidal via UAPP bit perfect & find metal sounds great across all sub genres, as long as the recording is decent of course, Bloodbath, Baest, Decapitated, Deserted Fear, Lowest Creature, Meshuggah, The Occult, also more milder metal / rock bands such as Tool, Aera, Dead Daisies, AC/DC, Opeth. The only downside is they highlight poorly recorded music annoyingly well to the point where I can't listen to it using them, so I save that for the car.And for heavy metal music?
I use LC2.5D (silver cable) + bass filter + JVC spiral dot eartip. That makes the sound natural and airy with full bass, smooth vocal and sparkling but not piercing treble.Any suggestion for budge full copper cable to warm FH7 a little bit?
Dear friend,Was enjoying this for some time... but unfortunately, just 1.5 years - it broke.
My Issues:
Left IEM ear piece is now very soft
I need to shift the audio balance manually to left
The lower bass on the Left IEM is not clearly audible anymore
What I did to try fix the issue:
Clean the IEM
Replace the MMCX cable
I used different devices to test i.e., my PC, iPad and iPhone and all have the same result as listed above...
Very disappointed, my very first IEM with significant cost, ends up breaking in less than 2 years with modest usage.
And to add... support informed me there's no way to fix and offering me to get a new one with discounted price - but with my experience, not sure if I'm buying another one.
Any other suggestion?
My Issues:
Clean the IEM
I have a pure copper cable (**** 4 core balanced 2.5 mm) and the FiiO pure silver cable (LC2.5D). I prefer the combination of LC2.5D cable + red filter + JVC Spiral dot++ for increased bass and moderately extended high frequencies. I also use the pure copper cable + green filter + Azla Xelastec eartips for enhanced mids (voices) and bass, but less extended highs. It depends on the source and mood.I use LC2.5D (silver cable) + bass filter + JVC spiral dot eartip. That makes the sound natural and airy with full bass, smooth vocal and sparkling but not piercing treble.
