[FiiO FH7] Flagship 5-Driver (1DD + 4BAs) Hybrid In-Ear Monitors, Knowles DFK + SWFK Composite BA Drivers, 13.6mm Beryllium DD Driver
Mar 11, 2020 at 6:17 AM Post #1,561 of 1,922
anyone else finding the FH7 not very compatible with different cables? every cable i try is too loose. when i tried the stock cable with other IEMs, the cable would not fit, it was too big.
I'm using a 16-core **** cable with 4.4mm connector, without any problem.
Mar 15, 2020 at 10:31 AM Post #1,562 of 1,922
Ok, my small update for FH7 dry bass. I should say that this is great bass for instruments, **** I love drums, I love strings, Hellfire by Barns Cortney is insane. Its just too dry for edm, seriously.
So, what helped me a little, I have Q5S as source, and neutral-neutral combination is just not working for me, but aptx adds the warmth that I was looking for. It's not the best in general, cause hight is messed a little, but at least it something for now. Also I ordered Oriolus BA300S, which should help me to fix it without loosing details, so when I'll receive it, I'll tell if it helped.
Just curious, did you enjoy pairing FH 7 with BA300S? what is your source?
Mar 19, 2020 at 1:38 PM Post #1,563 of 1,922
So I need some advice, the fiio llc-2.5d cable, is it a noticeable upgrade from the stock cable? I'm using a BTR5 with my FH7.
Mar 21, 2020 at 4:55 AM Post #1,564 of 1,922
Hello,
Generally, the 2.5mm balance output would have higer channel separation, with stronger stereo sense. And the LC-D cable is using pure silver so its material is theoretically better than the LC-B cable. But due to individual preferences, you could read the professional reviews and comparisons, as well as try out by yourself.
Best regards
Mar 22, 2020 at 12:36 PM Post #1,566 of 1,922
Is there anywhere I can buy the box for the fiio fh7? I bought it used from someone but they didn't have the box? Does anyone have a box they dont need that I can buy?
You can buy it at Ali Express!
Mar 22, 2020 at 9:00 PM Post #1,568 of 1,922
Mar 22, 2020 at 10:15 PM Post #1,570 of 1,922
Ohh thanks, but I mean the entire packaging, like where everything is unboxed
Oh...haha, sorry. I thought you meant the case. I doubt that one can buy only the package. Actually I never saw any box of any product be sold as "new", only used on Ebay etc. But who knows....Maybe you can write to Fiio?
Mar 27, 2020 at 3:47 PM Post #1,572 of 1,922
Hi guys, this is my first post over hear, maybe i'm posting it in a wrong place(sorry for that, and for my english). I am in a search for fun sounding iem with a bit of bass, not neutral sound.
I have ordered Fiio fh5 on amazon and i have played with the them the whole day.
The source was my macbook pro (2018),
flac library Bruno Mars , Daft Punk , AC/DC ...
And to be honest i liked the sound, bass especially!
Then i saw the Fiio fh7 , returned the Fh5 and than want to order fh7,but amazon does not deliver Fh7 to my country(Austria).
I have found the store with fiio fh7 in stock but there are no returns on in ear headphones.
So biggest question, should i stay to fh5 or does the fh7 have same amount of bass? I will be happy with a little bit less also but not drastically less :gs1000smile: .
Also i want to play youtube music/ cd ... not always flac,dsd, or other high quality files.
And what of amp+dac could you suggest me to pair with these iems ifi hip dac, fiio q1 mark 2 , topping nx4 dsd ,fiio q5s?
Sorry i am completely new this and i want to buy something that gonna last years.
Thanks and cheers!
Sasha.
Mar 28, 2020 at 4:08 AM Post #1,573 of 1,922
Thanks and cheers!
Sasha.
Hello,
Compared to the FH5, the output of FH7 extends to both ends, with better low frequencies, more detail at high frequencies, and a wider bandwidth.
And you could also have a try in the local store first.
Best regards
Apr 2, 2020 at 1:12 PM Post #1,574 of 1,922
I found it had a little less boom, but more speed and impact. I listen to a lot of metal and classical, so I like the sound on the FH7. Some reviewers have said they sound veiled, but I have not noticed that on my set at all. If I want more boom to the bass, I swap to the Sony XBA-N3 (dark, dark) or the Hidizs MS-4 (ridiculous thump). However, for brighter metal - the FH7.
Apr 6, 2020 at 9:02 AM Post #1,575 of 1,922
I have both the Sony XBA-N3 and the FiiO FH7. The FH7 is a bit brighter, and the bass much tighter. The Sony is less bright - in fact, typical darker Sony sound - with solid bass and a "smoother" sound to it. If I am listening to music with more intricate guitar, I prefer the FH7. If I am listening to same genre, but heavier - say, Black Sabbath - I prefer the Sony.
I am undecided N3 and FH7, in conclusion if you had to keep only one, which would you choose? I listen to everything from hip hop to classical, but the emotion that can give me a violin and a guitar, nobody beats it, in your opinion which headphones are more complete? And who has a better soundstage? Thanks a lot you would help me a lot
