- Jan 30, 2011
It has nothing to do with the post you quoted. If you have an issue with me - take it to PM.It comes from your blog and also your previous two postings before the above one.
I think you right. I mean "clarity" as natural reproduction, without emphass on high frequency. FH5 gives very natural sounding. But "transparency" usuallu means treble emphass afaik. It is not big in FH5, and also it causes not too big soundstage“clarity” with “transparency,
I listened to many of these, marked by the concept of transparency. There's just a lot of high frequency (IMFO of course)transparency means whether or not it sounds as if there is no barrier
@SilverEars , the Grado GR10e seems to have a particularly small sound stage, so both other IEMs could easily be larger (and are) without necessarily being particularly large. In fact, just as the Sennheiser HdD800 is well known in the headphone domain for its large soundstage, I wonder what the counterpart to a large soundstage IEM would be. Any ideas?
When I first joined head-fi in 2014, I posted a query asking folk to indicate what acoustic features they looked for in a headphone. Based on those comments (and based on advice received that each person has different preferences), I chose the 10 features that I did. Over the past four years, I have conducted well over 100 comparisons using that same feature set, providing a common reference basis, for good or for bad, to hold fixed as I compare various headphones. They are not without omission or fault — for example, there is no measure of vocal quality included. Furthermore, the simple rank ordering of three headphones at a time into first, second, and third place on each feature (rather than attempting to do an absolute rating of say high, medium, or low) tends to make small differences in performance on a acoustic feature seem larger than it is (and also tends to understate huge differences). However, it seems to me more error prone to try to rate, say, the soundstage of a headphone as H, M, or L in an absolute (rather than a comparative) sense, as that requires an attempt to figure out what an “average” sound stage across all headphones would be and how the headphone being examined compare to that average.
I want to ask you - what is your preference between FH5 and IT04?I'd say the largest sounding IEM to this date is IE80 from Sennheiser. It does not have a lot of instrument separation, but it is huge in size.
As for FH5, I'd say they are rather intimate, they place you next to the music
Absolutely agree with you, under each item. In the end, I left both for myself, perfectly complement each other. But because I am jazz funboy - FH5 most part of timeVery good question.
The most honest answer is that it depends on what I'm listening to. Some music simply works better with each.
FH5: Jazz, Electronic, Hip-Hop, Classic Metal, Thrash, Punk, Alternative, Dubstep, Techno, Downtempo
IT04: Orchestral, Symphnic, Symphonic Metal, Power Metal, -Core music (Hardcore, Post Hardcore, Emocore, Trancecore, anything that ends in core), Emo, Classical, Avant Garde
Have a search for a group called Portico Quartet. Jazz Fusion.Absolutely agree with you, under each item. In the end, I left both for myself, perfectly complement each other. But because I am jazz funboy - FH5 most part of time
The funny thing is that I never jazz listen before. But when I bought fh5 everything changed, now I practically only listen to jazz, so good on fh5, especially with the female vocal
You can listen and purchase on Bandcamp
