PROblemdetected
Previously known as sakt1moko
I finally bought the FA19 to add to my collection, and I really understand all your comparisons with other similar priced iems.This statement is not generally true. You can get a much bigger improvement for 1000$ than 5%, but not with the FA19 (which is the whole issue to begin with).
The first important thing is to understand, why do many IEM have Multiple Drivers covering the same range. And that might sound silly, but the reason is volume.
An traditional All-BA IEM start to distort already at around 100db and higher. So with using multiple drivers for the same frequency range, you can get up to 120db distortion free sound.
Do you listen at that volume? If no, all you do is wasting money buy buying a lot of drivers you don't need. And thats the biggest issue.
The FA19 is very expensive because it has 10 drivers, but there are IEM with 5 drivers that are better. Not at 120db Volume, but at listening volume (<=100db) That is very typical ChiFi, numbers on papers have to be big and you pay for those big numbers (no matter if there is a real improvement in sound).
FA9 was already tough priced at 550€. It was good, but 550€ was tough. I think it would have been better priced at 499€, that would be an fair offer. At the end of its lifetime, it was sold for 349€ which was an very good deal i recommended to a lot of people. I think a lot of FA9 have been sold just alone by my recommendationsWhy was it 550€ in the first place? Because it had 6 drivers. It was a 3-way system, but 2-drivers per way.
The Issue is, for roughly 350€ you can get the Westone Mach 30 (An 3-way system, just like the FA19), for 500-600€ you can get the Sony IER-M7 or Westone Pro X50 and the IER-M7 already outperforms the FA19 with 4 drivers.
Thanks to the weak yen (that is a but unfair, yes) the IER-M9, one of the best IEM that ever existed and easily outperforms the FA19, costs ~900€ (including shipping and taxes). An realistic price for the IER-M9 is around 1300€. But even for 1300€ it is still worth every cent.
So you can get better quality, you just have to be careful what you buy. Quality over Quantity. 5 good drivers in an well made 5-way system over 10 Drivers in a 3-way system where more than 2/3 of the drivers play the exact same sound and so are basically just for lower distortion at insanely higher volume. So don't give up on high end IEM yet, just be more careful what you buy and check exactly what technology is used and what exactly is this technology used for.
But if you compare with more expensive iems (like 12t for example, wich cost the double) you could get the same reactions.
Also, really the z1r is so much better than the tanchjim oxygen?
Is the arya organic better than the ananda nano?
Its hard to recommend any equipment over 300€. After try multiples iems, I always say: " you can end the game with the VARIATIONS, wich cost roughly 380€"
Also, this is probably the best FiiO iem never made, no only for the profile, the working switches, the beautiful cable, magnificient fit or durable mmcx connectors. It just have the best sound Ive heard an all earphones Fiio made.
All brands, got iems over 1000, like THIEAUDIO, with worst quality of build, worst warranty and really big problems of QC.
Probably the M9 is one of the fullBA of the market, but the FiiO is close enough to be a contender. And I would recommed over the 12t in price/perfomance ratio.
Just my two cents.
