My graph is quite a bit different to Chris's - but is aligned to what I'm hearing.
Usual disclaimer .......
The graphs I use are generated using the Vibro Veritas coupler and ARTA software. Ken Ball (ALO/Campfire) graciously provided me with measurement data which I have used to recalibrate my Veritas so that it mimics an IEC 711 measurement standard (Ken uses two separate BK ear simulators, we measured the same set of IEMs, and I built my calibration curve from shared data). I do not claim that this data is 100% accurate, but it is very consistent, and is as close as I can get to the IEC 711 standard on my budget. I suspect it is slightly down at around 9-10 kHz, and tend to dip slightly at sub bass with foam tips), but seems reasonably accurate through the rest of the spectrum.
I do not claim that the measurements are in any way more accurate than anyone else’s, but they have been proven to be consistent and I think they should be enough to give a reasonable idea of response – especially if you’ve followed any of my other reviews. When measuring I usually always use crystal foam tips (medium bore opening) – and the reason I use them is for very consistent seal and placement depth in the coupler. I use the same amp (E11K) for all my measurements – and output is under 1 ohm. FTR - FiiO has consistently mentioned that my graphs are in line with their own measurements.
Bass is nicely matched to both upper mids and lower treble. Very good bass extension - including sub-bass. But its really clean bass. There is sufficient rumble, but its not over-done. Mids tend to favour female vocals just a little, but again not excessively. Male vocals are ever so slightly on the lean side, but not unpleasantly so. There is enough lower treble to allow detail without getting splashy. Cymbals sound great.
I like the FA1 a lot more than the FA7. A touch cool - but with enough bass to give impact.
Great fit. These are really to my tastes!
