saintyoo
- Dec 28, 2010
I just received the e7's (first amp with the ath m50's!) today and it worked great at first.
The first thing I noticed was that the bass booster distorted the bass, although I saw in another thread that it might be because of my sub-par laptop sound card. I'm going to try other sources, other laptops, ipod, etc to see if there is an improvment.
Number two... after about 3 hours of use, the e7's started to mess with the laptop's sound drivers (at least that's what I believe). Frequently, after I plug the USB in, or when I try to play a FLAC file after the USB is already plugged in, sound would stop working on Winamp/mediamonkey/firefox/etc but strangely itunes and the volume indicator noise still worked. Other times, the sound stops working completely. I thought about just using the male to male and not the USB but then the e7's doesn't function as a DAC right? I know that in the instructions it says to restart the media player application after connecting the e7 or you may lose sound. I did that but I don't think that this sort of problem is what the instructions were talking about.
any help/suggestions?
