teknov
- Feb 3, 2010
I have a question did any of you guys have a problem with the clip screw popping off? I CA'd mine on.
The E5 hisses a lot with low-impedance/high-sensitivity phones like the UE10.
Get a decent MP3 player, then you don't need an amp with them. Cowons and Sansas can drive multi-armature IEMs perfectly fine, Sony players can't, for example.
Quote:Get a decent MP3 player, then you don't need an amp with them. Cowons and Sansas can drive multi-armature IEMs perfectly fine, Sony players can't, for example.
Not a helpful answer I feel.
Quote:Quote:Get a decent MP3 player, then you don't need an amp with them. Cowons and Sansas can drive multi-armature IEMs perfectly fine, Sony players can't, for example.
He is trying to drive ultra-sensitive $1000 custom IEMs with a $20 amp. My recommendation of getting a better player was genuine.
Ah, I see... UE10, as you've written above, is something rather different than the TF10. I think they're discontinued now, replaced by the UE Reference. Either way, the least expensive amps I know that don't hiss with phones like the TF10 and can drive them properly are the Corda Headsix and the Headstage Arrow.
