JoshuaA
- Feb 15, 2014
Hi, which version is J211A? The store couldn't tell me on the phone? Thanks
Hi, anyone tried Foobar2000 + Wasapi component + 24bit 96Khz FLAC audio file > USB out > FiiO E18? I'm listening them with my Shure SE535 reds and I can't seem to decipher much difference between an 320kbps encoded mp3 and a HD audio file, if at all.
I get the readings on the Foobar player that it is outputting the 96Khz audio but I also read that Wasapi is suppose to mute all other sounds when it is working. My discontinued Winamp player also shows it is playing the FLAC @ 96Khz but is there any way we can really know if we are getting the high fidelity audio output?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
If you guys are having trouble with your e18 cutting out when tethered to your android, try going into airplane mode to see if the problem isn't your phone looking for a signal and dropping power to the otg cable (which kills the E18's ability to function).
That sounds like a logical possibility for some but not me unfortunately. I live in the sticks where there's zero coverage so I'm pretty much permanently in Flight Mode. It might work for others though.
Same with me, phone used for music playing only so doesn't have a SIM.
Postman has just this minute delivered two OTG cables ordered from Amazon marketplace with the intention of joining them together to replace the right angled adaptors I'm currently using ...
... but the supplier has sent straight ended ones rather than the right-angled ones I ordered ... arrgh :mad:
Got a link?
Does the "A" signify 1st generation?
How can I tell if the unit is the latest model?
Thx
I ordered those 5 pins to be used with the FiiO short OTG cables http://www.ebay.com/itm/Pair-90-Degree-Right-Left-Angle-Micro-USB-Male-to-Micro-Female-Plug-Adapters-T7-/131057882036?ssPageName=ADME:L:OC:US:3160
Have you checked that 24/96 is enabled on the E18 in the driver settings?
BTW, if you're running windows 7, this hotfix from Microsoft is required to prevent audio bugbears from cropping up in the case of resampling
http://support.microsoft.com/kb/2653312
An analysis of window's audio performance before and after the hotfix
http://www.indexcom.com/tech/WindowsAudioSRC/
