Dec 18, 2012 at 8:15 PM Post #196 of 1,676
Yeah I got my Andes from the Micca Store Distributor and its legit. Also, previously got my E6 from SMICORP and it is legit
Dec 18, 2012 at 9:12 PM Post #199 of 1,676
battery life only 20 hours? i remember my E7 has x2 or x3 battery life xD
It is the cost for sound quality, actually the batter capacity increase about 40% compare with E7
Dec 18, 2012 at 9:15 PM Post #200 of 1,676
I got about 16-18 hours with it and yes, bigger battery, but more power usage.
@James of FiiO
The majority of my review is up.
I'll finish up the sound section tomorrow or the next day. I did too many reviews today.
Dec 19, 2012 at 2:06 AM Post #201 of 1,676
well 20 hours is still great. im not saying its bad though! i should have tried this one when i had the chance during one of the meets here in our country.
Dec 19, 2012 at 3:42 AM Post #202 of 1,676
I haven't used the amp at least 5 days and when I turned it on today to check the battery it was still full. My E6 would die after not using it for a few days
Dec 19, 2012 at 3:11 PM Post #204 of 1,676
tried to get it work with stock 4.1.1 "international note 2", sadly it didnt work, which stock build and kernal u r using?
Just got my E07k and tried it with my Note 2 I317M and voila, nothing.
Did you make sure the dock setting is set to play audio when dock is connected?  I tried on and off and did not work for me.
What kind of cables are people using?
Dec 19, 2012 at 3:40 PM Post #207 of 1,676
Tried that one too and another from ebay that is a micro to mini usb.  None work.  I'm on stock.  There must be a setting to play with???
Well, I am sure it works different with different phones.  I have a rooted Galaxy S III running Cyanogenmod 10.  I have no idea if it will work with mine.  I will report my finding when I get the cable in a few days.
Dec 19, 2012 at 5:09 PM Post #208 of 1,676
i used OTG cable for the connection, the OTG i used already tested with mouse, keyboard and external hard disk and its working, when i plugin the andes the sound goes mute and in the music player the music plays fast, i have installed USB Device info and it shows that the andes is been connected to the phone, >_>
Dec 19, 2012 at 5:28 PM Post #210 of 1,676
Yup, that's exactly what happens to mine.  All audio and video will go like it's FF or something and can't hear anything.  I checked the cable and USB drive works. Strange behaviour.  Too bad, I was really looking forward to this working and one of the reasons I upgraded to the Note 2.  I have the I317M - Roger's Canada stock.
