Expected to be available in September
Any plan to sold it via AliExpress also?
Did you read his answer? Doesn’t compress.I mean how much does the ESP compress the audio when it's enabled and listening to CDDA? Does the ESP compress the bit rate to 320kbps, 256kbps, 192kbps or even lower? Just listening through the headphone jack.
Did you read his reply to me from July 24th? He explicitly said that the ESP is compressed.Did you read his answer? Doesn’t compress.
1, after ESP is opened, the file is compressed, the compression time is 60 seconds for CD format and 120 seconds for MP3 format.
2, when ESP is turned off, the audio stream will not be compressed.
So it is recommended to turn off the ESP switch in non-mobile scenarios to get a better listening experience.
I'm not sure if it's subject to change, but it was said to be $179What's the estimated USD price for this? I'm pretty excited to see this since I just started re-collecting CDs again.
HELLOIf anyone has questions, reply here and I will discuss them with you!![]()
Thanks for posting. Looking forward to having one soon!In case some of you haven't seen it, Fiio posted this on Facebook. First time I see the translucent cover.
Will be in the end of Sep or OctAny plan to sold it via AliExpress also?
The DM13 will come with a 3.5 to coaxial cableWhat coaxial cable will I need to connect this Cd player to my Fiio Alpen E17k 2 DAC?
I'm sorry, I don't have any data on that.@FiiO Willson Any word on how much the ESP compresses CDDA when just listening through the headphone jack?
That's interesting. So a cable with a build in ADC?The DM13 will come with a 3.5 to coaxial cable
I have a suggestion for the DM15, if you were serious about FiiO eventually selling a DM15. Maybe the ESP switch could have 2 positions, the first position would be a 10 or 15 second uncompressed ESP, while the second position would be 60 seconds compressed.I'm sorry, I don't have any data on that.
But when I listen to music, I think it sounds better without ESP than with it on
