[FIIO DM13] HiFi Balanced Output Portable Stereo CD Player DM13 Is Officially Released!
Aug 29, 2024 at 11:15 AM Post #122 of 763
That's interesting. So a cable with a build in ADC?
No.
You will need a 3.5mm to 3.5mm cable for your E17k.
It is not clear how the DM13 will switch between coax output or line out, since they share the same port. Through a connected app maybe?
Or maybe the supplied cable will short one channel and the DM13 will then enter coax mode, in which case you would need a mono cable, not a stereo one.
I'm guessing here. Perhaps @FiiO Willson knows the answer already?
Aug 31, 2024 at 5:33 AM Post #124 of 763
The Fiio Alpen E17k 2 DAC came with a 3.5 (TR male) to coaxial (female) cable -- pictured here. Will the DM13 cable be 3.5 to coaxial (male) to connect with this pictured cable? Or will a 3.5 to 3.5 (TR male to TR male) suffice?
Yes, a 3.5 to 3.5mm cable will be ok.
If you can, it's best to use a 3.5 to 3.5 coaxial cable
Sep 4, 2024 at 9:58 PM Post #126 of 763
Or, will the DM13 send audio to the Fiio Alpen E17k 2 DAC via USB? Will the Alpen recognize the DM13 as a USB source?
Sorry , DM13 can not send USB format audio to other device.
DM13 can output WAV format file of the CD's to USB Storage or PC :beerchug:
Sep 5, 2024 at 3:56 AM Post #127 of 763
Yes,It has USB Audio Out
Perhaps you should edit that previous post. The term 'USB Audio Out' means you can connect it to a USB DAC.
If I've understood correctly, the DM13 can act as a CD drive for a PC so it is a USB Client device, not a USB Host.
Sep 5, 2024 at 8:11 AM Post #128 of 763
This. I also was under the impression that I can connect the DM13 to an external dac. I was excited about this because I use the Topping D50 III, which has built in PEQ that only works with USB input.
Sep 5, 2024 at 9:12 PM Post #129 of 763
Thanks for the suggestion, edited
You are right, We need more time to complete the technology turnover, and expect this feature(USB digital Audio Out) to be implemented in the next generation of CD players
Sep 8, 2024 at 9:09 PM Post #132 of 763
Sep 8, 2024 at 9:10 PM Post #133 of 763
Will FiiO be release a software to for this function? If so, will the WAV file contain meta data such as album name, artist name, and album cover?
No, you can use the software of Windows and MAC, They are both good enough
Sep 13, 2024 at 4:07 PM Post #134 of 763
Is DM13 still a prospect for September with dealers?
I can't find it on Fiio website at moment.
Sep 13, 2024 at 8:53 PM Post #135 of 763
We're in mass production now, and we expect to start pre-sales in mainland China around September 23rd;
Shipping in mainland China at the end of September :beerchug:
