[FIIO DM13] HiFi Balanced Output Portable Stereo CD Player DM13 Is Officially Released!
Nov 8, 2024 at 8:20 AM Post #256 of 739
German guy here. I've received my unit yesterday. Built quality is very nice, sound as well. But... there are a few things that bug me.
@FiiO Willson
Hello to China. I have a few questions about the DM13:
Will there be firmware updates? Because it has some issues I hope that would rectify.
1. Battery charging is not constantly visible. A small LED somewhere on the unit would have been nice to indicate it's charging (perhaps an idea for a potential successor). Alternatively, a display being kept on, saying "charging". Because as of now it just says "charging" a few times and then it goes dark so I never know if it's charging or not.
2. Gapless doesn't work all the time. Sometimes it's just gapless for every other track, sometimes it isn't gapless after you've been searching through a piece of music with one of the foward/previous track buttons
3. Sometimes next track / previous track buttons won't work properly, they exchange their function, next track turns into previous track
4. Sometimes the play/pause button turns into previous track. In both cases, player has to be restarted.
5. It would be nice to be able to switch off the "resume" function. So far, it appears to resume when you change function (from S/PDIF to Bluetooth for example and back to Pre) during playback.
6. (EDIT): For some CDs, the first second of music is cut off after you've switched the unit on (I assume it's because the output is muted before playback has started).
To everyone else: the buffering function (ESP) always has some part activated. I haven't measured it but I assume that, as long as the ESP switch is off, it's lossless. Meaning: even with ESP switched "off" you will have some skipping protection.
Nov 8, 2024 at 10:27 AM Post #258 of 739
It has optical out. The3.5 mm output is multiuse. You could use it if you modi has optical in.
Thank you.
I can use both coaxial and optical cable in the Schiit Modi Multibi.
In my second DAC the Khadas Tone board only cable coaxial (it should be like that).
Nov 8, 2024 at 10:32 AM Post #259 of 739
@FiiO Willson
Gapless playback not being consistent is a big issue, hopefully this can be resolved quickly and isn't present with every unit
Nov 9, 2024 at 1:38 AM Post #261 of 739
@FiiO Willson
May I ask if you have purchased the silver version, this can only be sold within China. However, your machine doesn't feel very stable, I'm not sure about the state you're describing
We already have the new version of the software upgrade
The black and white machines have the latest firmware. :beerchug:
Nov 9, 2024 at 7:40 AM Post #262 of 739
Since I'm in Germany I've ordered from the official German retailer (fiio-shop.de). Meaning, I have the black version (since it's the only one available). And you're right, the machine doesn't feel very stable. It works when doing nothing but playing CDs but once you start interacting with it, it gets tiresome.
Nov 10, 2024 at 6:56 AM Post #263 of 739
@Marlene I am seeing exactly the same as you with the gapless playback (and other issues). Sometimes it works, and sometimes not, regardless of ESP state.
More concerning, I also get small skips and silent gaps within a track. They also seem random and ESP has no effect.
The fast forward/rewind don't always work, and when they do they jump forward/backward by a random number of seconds. They also always play sections of the track, even when paused.
I wrote up more of my findings here before I found this forum: https://www.reddit.com/r/Cd_collectors/comments/1gnbx3j
I have a black DM13 in the UK.
Edit: I've also just noticed it lost battery overnight while it was off. It went down from 5 to 4. I had charged it for a few hours before bed and left it off overnight.
On a more positive note, other than the issues, it sounds so good I am discovering a love of music I have never had before.
Nov 10, 2024 at 7:43 AM Post #264 of 739
The findings you posted on Reddit align with my own. Though I haven't tested every function (Ripping to USB stick, for example). I also had problems with playing CDs consistently and also found that it skips within CDs, albeit rarely. On my own post I concentrated on the issues that felt, to me at least, the most important.
For all these reasons, I've decided to return it, I've just started the return process. It sounds good, very good in fact, it's the best sounding portable CD player I've ever heard (and I've heard many!). But good sound isn't enough when operating the unit is sketchy or feels unreliable.
Nov 10, 2024 at 7:46 AM Post #265 of 739
I'm hoping there's a firmware patch that can fix these issues - they don't feel like hardware ones, other than maybe the button presses. I'll be keeping it for a bit because AliExpress seems to have a 90 day return period for it.
I really want to like it, and when it works I really do. It just feels very beta.
Nov 11, 2024 at 4:48 AM Post #266 of 739
I think there's been a misunderstanding.
The black version of the DM13 uses the new firmware and the work is very stable. Are you still not understanding how to go about it?
The DM13 has a lot of features that require some learning costs
Nov 11, 2024 at 4:51 AM Post #267 of 739
About what you said about "the battery was off" on night.
Is it possible that you put the D.MODE switch on the back to ON?
If this is the time, you have to plug it in to turn it on
In other words, if you want to leave the power supply on, you have to turn the D.MODE switch off.
Nov 11, 2024 at 4:54 AM Post #268 of 739
I think what the user above is saying is an operational issue
We also had a lot of users at the beginning of our sales in China who were not used to operating the way we did. It's a very versatile product, not a single function CD player, so I think it's normal to not know how to operate it!
If you have time please check this link:
https://www.fiio.com/dm13_faq
Nov 11, 2024 at 4:55 AM Post #269 of 739
I had turned the player off (not left it to turn itself off) when the battery was on 5, and left it plugged in for a couple of hours extra, then unplugged it to move it. When I turned it on in the morning and the battery was on 4. Desktop mode was off the whole time.
Nov 11, 2024 at 4:59 AM Post #270 of 739
The button presses are an operational issue. I find them confusing. Whether that's a design issue with the interface approach, or my own one for not having the type of brain that remembers lots of unlabelled combinations, is up for debate.
A fair few of the other issues seem like software bugs though.
I wanted to include it as some feedback (because I also design tech products/user interfaces as a career), and it sounds like a lot of your Chinese users have the same issue?
