scracy
Fast becoming a new favourite pairing with the BTR7
+1 for FD7Crazy how good Fiios own IEMs and buds sound with their own Bluetooth source. It is like they designed the source to go with them.
It seems that when the TR-63 came out, radios small enough to be slipped into a pocket were known in the US as "pocket" radios. Today the word "pocketable" appears in English dictionaries. We now use it without a second thought, but who would ever guess that it originated as a Japanese-English term invented by Totsuko when it launched the TR-63?
Unfortunately though, the TR-63 was just barely larger than the pocket on a typical businessman's dress shirt. The catch phrase would have lost its punch --- except for a little ruse on Morita's part. He had shirts custom-made for his salesmen featuring a slightly larger pocket.
+1 more for the FD7+1 for FD7
Never got a reply to this. Could anyone answer any of these questions?Don't know if this question(s) have already been asked...
- The BTR5 had mic passthrough i.e. if your cable had a mic it would passthrough and be used by the BTR5 instead of the built in mic. Does the BTR7 do the same?
- If the above is true, if the BTR7 is used as a USB DAC via PC will it recognize the mic either the built in mic on the BTR7 or the one passed through via the cable?
- Is there a case with a clip or beltloop or something to secure it to a shirt? (Pictures in the gallery show some sort of magnetic strip?)
How btr7 compared to m11 plus ess. Is tuning similar? Is it far behind or not so ?Fast becoming a new favourite pairing with the BTR7
If you hook the BTR 7 up to your PC, will the USB bypass the battery in order to increase the life-span? I think the 5k does this!
It will still draw the battery regardless of the switch position, I don't think THX amps can operate on USB power alone, but would be interesting to hear FiiO response.No, but you can turn charging on or off with the side switch.
They are similar but slightly different at least if you are using BTR7 wirelessly (I haven't used BTR7 as a wired DAC). M11 Plus is a very neutral source whereas in my opinion I find the BTR7 very slightly boosted in the treble and bass frequencies (using LDAC and no EQ hybrid fast digital filter) kind of like an old school "loudness" button on a boombox but much much more subtle, also I find the soundstage to be more of a holographic presentation than that of the M11 Plus. This is why I personally prefer using both the FiiO FD7 and FH7S with the BTR7 as opposed to the M11 Plus which to my ears sounds better paired with the FH9. In terms of overall sound quality they are similar just one is more neutral than the other but not by much, if you own an M11 Plus ESS you will enjoy the sound from the BTR7 if thats what you are askingHow btr7 compared to m11 plus ess. Is tuning similar? Is it far behind or not so ?
Thanks a lot, yes i was looking to know if btr7 isn't too colored or warm compared to m11 plus ess thas is quite neutral as i like a little bit more neutral profile. And seems i should like btr7 in such small package as alternative to bigger daps with it's sound tuning .They are similar but slightly different at least if you are using BTR7 wirelessly (I haven't used BTR7 as a wired DAC). M11 Plus is a very neutral source whereas in my opinion I find the BTR7 very slightly boosted in the treble and bass frequencies (using LDAC and no EQ hybrid fast digital filter) kind of like an old school "loudness" button on a boombox but much much more subtle, also I find the soundstage to be more of a holographic presentation than that of the M11 Plus. This is why I personally prefer using both the FiiO FD7 and FH7S with the BTR7 as opposed to the M11 Plus which to my ears sounds better paired with the FH9. In terms of overall sound quality they are similar just one is more neutral than the other but not by much, if you own an M11 Plus ESS you will enjoy the sound from the BTR7 if thats what you are asking
Truthfully I reach for the BTR7 more often than I do for the M11 Plus, so convenient and great soundThanks a lot, yes i was looking to know if btr7 isn't too colored or warm compared to m11 plus ess thas is quite neutral as i like a little bit more neutral profile. And seems i should like btr7 in such small package as alternative to bigger daps with it's sound tuning .
Dear friend,Never got a reply to this. Could anyone answer any of these questions?
