MrWalkman
How to?
I don't think you can do that on the BTR7, though I wish we were able to deactivate multipoint.
How to?
Multipoint and LDAC are not mutually friendly. Technics EAH-AZ80 manual for instance recommends to disable multipoint if optimizing for Audio Quality.
I've heard that as well. But I've been using Aviot TE-ZX1-PNK in LDAC and it stays connected to my DAP and phone without a hitch.Multipoint and LDAC are not mutually friendly. Technics EAH-AZ80 manual for instance recommends to disable multipoint if optimizing for Audio Quality.
I swapped btr15 to btr7 for the bigger battery (I hope)
Set my EQ just like on the btr15, but the low-shelf is not remembered, always switches back to shelf if I re-enter the EQ page again in the app.
Known issue?
Dear friend,I have these kind of issues where my personal custom PEQ sometimes reset when I open the app, using latest app version. I've told Fiio representative here some times ago.
Seems everything is okay now and also thanks to realized my request months ago to finally be able to have custom name for PEQs instead of EQ custom 1 2 3. Simple but really helpful.Dear friend,
Hi, are you using the latest FiiO Control 3.22 and BTR7 firmware FW2.02?
We will report to the engineer to test more.
Best regards
