There is no hard industrial definition of what 'line level' has to be. Besides the fact that most will agree that a line level signal should be the cleanest signal a device can offer, most companies just make up their own number / voltage. Before the age of iPod, most audio companies used 2V as standard. But iPod was so popular that the industry started to follow Apple to lower their line-out to 1V, then to 0.5V (which was basically what Apple offered on their iPod's line-out dock). After iPod is gone, these days you will find different voltage all over the place. Chord for an example like to use 3V, which will most definitely clip most older amp that was made to follow the Apple's standard. Generally speaking, 2V is still the most common choice due to legacy reason but it really depends on the manufacturer.
Now going back to BTR7 - since we want the cleanest signal (= lowest distortion / highest SNR) for double amping, the measurement done by L7Audio lab already shows us that it should be around 1.2V or so on single-ended or 2V for balanced output.
