aravaioli
Got my BTR7 yesterday and the power measurements found in another forum didn't lie: it is not more powerful than my BTR5 unless you select the "boost" option, only available through the Fiio app, where it gets a very modest advantage. SOUND IS VERY SIMILAR and possibly a bit less congested than the BTR5 in some situations.
Mine is going back to the seller but I want to be clear: it is a good product. But I am disappointed at Fiio for its misrepresentation of power output in its specifications.
Nothing like trying yourself, do a favour to yourself and forget the various YouTube promoters. If I didn't have the 5 I would have probably kept it.
However the iFi Go blu has an evident formfactor advantage and the Qudelix has that outstanding app.....
In terms of volume my experience with my Focal Clear Mg with balanced cable to reach 80db was:
BTR5 = BTR7 (40/60 volume)
QUDELIX 5K (90/100 volume)
IFI GO BLU (75/100 volume)
BTR7 with boost would need a volume of 37/60.
With my Arya v2:
BTR5: VOLUME 55/60
BTR7 boost on: Volume 45/60
BTR7 boost off: Volume 54/60
With my Arya v2:
BTR5: VOLUME 55/60
