newworld666
I did a a second test today .. this time, in Aptx only BT receiver mode =>5h51 playing time not more on a full battery charge. It's far from being sufficient for my use.
Did you try restarting app and device after update, I had something similar (disabled PEQ), until I rebooted both.Thank you
I made the firmware update yesterday when I got the BTR7 and it's FW1.71... I just saw a Graphic EQ and just tried to activate the equilizer, but I get a message that I am connected in LDAC ..
When I am not in LDAC mode I could see et PEQ parameters .. so sorry ..
Any reason that EQ is not allowed in LDAC mode ? do I miss something ?
I will do just this to see what happens, but as battery life is rather anorexic, I don't intend to use any DSP features of the BTR7..Did you try restarting app and device after update, I had something similar (disabled PEQ), until I rebooted both.
You thought almost desktop class amplification in a form factor small enough to be hidden between your palms would also come with extended battery life? That's... optimistic.I did a a second test today .. this time, in Aptx only BT receiver mode =>5h51 playing time not more on a full battery charge. It's far from being sufficient for my use.
It's so huge and heavy compared to the iFi Go Blu or even the Qudelix => that yessss !!! I was really expecting a similar battery playing time in the same league as the iFi Go Blu, but with a nice Thx amp (fast impacts and totally hiss free even with my sensitive IEM).You thought almost desktop class amplification in a form factor small enough to be hidden between your palms would also come with extended battery life? That's... optimistic.
3. How is the battery life of the BTR7 under LDAC Bluetooth?
There are some differences between different Bluetooth codecs. Please refer to the following test data for details.
1) AAC + Low gain + 3.5mm output: About 9 hours
2) LDAC + Low gain + 3.5mm output: About 8.5 hours
3) AAC + Low gain + 4.4mm output: About 8 hours
4) LDAC + Low gain + 4.4mm output: About 7.5 hours
This is what it says on original post. Looks 12 hours playback could be quite a bit of a stretch, did you check spec before puling the trigger.
Are you within the returns window? While there are those who are very happy with the BTR7, if it does not meet your expectations you should find a product that does.Yes I did before pulling the trigger....and, as I already said several times since yesterday, 8 hours for a BT LDAC receiver => was my playing time target for a typical 12 hours full working day... something less than 6 hours without any DSP features is significantly under my expectations !
I am 70 to 80% vol level in low gain 4.4mm.
I don't agree a good BT DAC/Amp is far from being simple ... most on the market are underpowered, can't accept balanced IEM .... etc I would say unusable with 2022 standards.Are you within the returns window? While there are those who are very happy with the BTR7, if it does not meet your expectations you should find a product that does.
Life’s just too short to be unhappy over something as simple as a BT DAC/Amp.
I own and use the iFi Go Blu, I still own and don't use anymore the Quelix and Es100 mk2 .. The Ifi Go Blu which is on most point a satisfying product....but can't be used over 24/96 in USB mode.
I need more time to evaluate the benefit BTR7 for some specific uses, including how fast it can be charged in real life or be used still connected permanently to a power plug or my working station.. how is power connected to a working station and is it still hiss free.
Till now, It's not a big deal to have spent 200€ in a BTR7. Nothing to worry a lot.
It’s still kind of an emerging market. Dongle dac/amps had (and continue to have) their moment and now it’s shifting to battery powered dac/amp/Bluetooth adapters. Bluetooth itself is a work in progress and may or may not be the ultimate wireless solution for audiophiles. I doubt I’m saying anything you don’t already know. My only point is that the choices are pretty good right now and will get significantly better over the next couple years.
I would fully expect some kind of true lossless wireless codec to emerge in the not-to-distant future. Maybe the new aptX or possibly something from Apple.
