Andrew_WOT
- Jan 18, 2004
L7Audiolab took some measurements of BTR-7 and more expensive EarMen Colibri, if interested. Doesn't look that Colibri impressed him esp. at the asking price.
YesAnyone able to get 24 bit audio when connecting to Mac via USB?
I've been doing some comparisons BTR7 vs Earmen Sparrow side by side via USB. Have to hand it to the Sparrow, it's worth it's weight in gold - with IEM specifically it has a more organic midrange, the highs are more refined, the bass is more bloomy and bouncy, and the soundstage is larger but also better defined by a good amount - there's clear space between the instruments and accurate localisation, to an extent one can almost hear the room they're in. The BTR7 ofcourse has more power (and lot more features), and can drive bigger cans - but I would say it's sound is about 70-80% of the Sparrow's with IEMs; there's some blurring in the high registers, a little less definition and soundstage, some slight feel of grayness in the background, and it just doesn't quite reach that wow factor and ease of the Sparrow, which is probably subconsciously compounded by how tiny the Sparrow is!
Anyway this is purely sound quality comparison - the BTR7 is indeed very good, but it's not quite a giant killer where the Sparrow kind of is when it comes purely on sound IMO (with all it's quirks).
Do you mind sharing how?
Zococity.es@FiiO Are Therese any FiiO resellers in Spain (Marbella or Malaga preferable) with BTR7 in stock?
Thanks but it’s to far away annoyingly.Zococity.es
Typically for me it means smooth, easygoing and natural - but not necessarily in an overly warm kind of way, or rolled off. This is typically due to an amalgamation of different technical qualities of the dac/amplifier - micro details, quality attack/decay (nuanced), low SNR/THD, good current drive and power, etc etcNot that I haven’t heard it before, but I’d like to know what “organic” has to do with any particular sound, instrument, or quality of sound?
I had the DAC clock divider setting available prior to installing the new firmware default value was 1/4, since then its no longer accessible.I noticed a BTR7 reviewer on YouTube showed a "clock divider" feature on the Fiio control app which can tweak the sound quality. I can't find this on latest Fiio control apps from app store and Google play. Does anyone have this?
Preset EQ settings, except for 2 or 3, others seem quite intolerable. Seems they are not correctly preset. Anyone else also noticed or they are OK as per genre? Preset EQs from other apps/devices didn't seem that bad!Still trying to figure out which one is better but first impressions.. BTR7 is awesome! Dead silent to my ears irrespective of SNR value. Amazing clarity and am yet to explore it. I would really recommend it. I did not have any version of BTR5 in any case.
