How would you rate the sound quality?
[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
- Thread starter FiiO
Guacamolly
@FiiO last night I used the wireless charging and I let it on the charger all the night. This morning I took my btr7, it was very warm like 30 celsius.
Is there any features who stops the wireless charging when it's full maybe a firmware update soon??
Big In Japan
@FiiO Did you hear back from your develpoment team already if this feature will make it to the roadmap? Not knowing if this will be implemented in future firmware/app-versions holds me back from buying and probably others as well.Hi @FiiO: At least 5 custom banks, the more the better. Actually your competitor Qudelix has plenty of them and I reserved one for each of my IEMs / "portable" headphones + it is usefull to have a few extra slots in order to quickly A/B test different settings.
It would be also fine, if the user could overwrite the presets, if internal storage capacity would be a limiter.
Thank you.
Thank you and greetings
Markus
Andrew_WOT
- Jan 18, 2004
Go few pages back,it was answered already.@FiiO last night I used the wireless charging and I let it on the charger all the night. This morning I took my btr7, it was very warm like 30 celsius.
LasherV
Since FIIO did not include a clip or other way to carry the BTR7 I thought I would share this simple DIY fix. You can take a common household Fork and push your favorite chain or cord through the back of the included leather case and wear the BTR7 around your neck. Hope this Helps
Lasher
Lasher
Great, no eq.How would you rate the sound quality?
Dsnuts
- Jun 20, 2011
Surprised at how powerful this little thing is. Drives my Amiron Homes with plenty of headroom. More importantly the SQ on this is surprising. Not much of a drop off going from my Fiio M15 to the BTR7. If any at all. Love how dynamic everything sounds using the BTR7. The BTR7 has me rethinking what is possible for portable dac/amps.
Just let a friend hear the BTR7 and it immedately put a smile on his face. Guy wants to buy one now. lol.
Surf Monkey
- Nov 7, 2011
Dear friend,
Yes, the FiiO Control app may not work fine when BTR7 connecting to two device at the same time. So you need to disconnect it from one of the device first.
Best regards
This is also the case with the BRT5. I have to be aware of which two sources the BRT5 is connected to at any given moment. The device can stop producing sound output if both sources try to access it at once. If I know it’s connected to a source I’m not currently using I’ll manually disconnect it from that one.
arrakian
- Apr 21, 2005
Do you mind sharing how?
I have the SoundSource app installed. It lets me select the output rate I want (so long as the DAC supports it).Do you mind sharing how?
Dear friend,@FiiO Did you hear back from your develpoment team already if this feature will make it to the roadmap? Not knowing if this will be implemented in future firmware/app-versions holds me back from buying and probably others as well.
Markus
Yes, they will try to add more custom EQ for BTR7 in later firmware update.
Best regards
Dear friend,I had the DAC clock divider setting available prior to installing the new firmware default value was 1/4, since then its no longer accessible.
The option does not function in BTR7 actually, so we have removed it in the new update.
Now we have kept the sound output preformance without changing the DAC clock divider level. Previously, we added the DAC clock divider function for BTR5 in order to save the power consumption. But we test that in BTR7, the battery life does not have big difference when DAC clock divider level is changed. So we have canceled this at last.
Best regards
Extorsivo
- May 9, 2016
@FiiO
i am very impressed by the specs of the btr7!
But a question comes to my mind...
Is there any chance, we will see an utws7 with THX AAA technology any time soon?
And maybe with 3.5mm connectors (something like BTA10)?
So we can make some over-ear headphones like beyerdynamic T5/T1, Denon AH-D 5/7/9200, Focal Elegia/Clear/Stellia, Meze 99/Liric, Monolith m1070c & so on, to a portable headphones?
Andrew_WOT
- Jan 18, 2004
There are so many adapters available, I even been using 4 pin XLR terminated big guns out of BTR7 with adapter.And maybe with 3.5mm connectors (something like BTA10)?
Direct connection could be better, but for small case like this to cram in all types of connectors is quite challenging, plus while plenty powerful it's still preliminary designed for portable use and portable headphones/iems.
@FiiO , Though bit off topic, any plans to bring FD7 kind headphone, beryllium diaphragm and FD7 like tuning? FD7 has been my favorite IEM and synergizes so well with BTR7. What's missing is an FD7 headphone!
Great, no eq needed imho.How would you rate the sound quality?
