newworld666
@newworld666 , I agree with @pacmanbr
It is always better to set LDAC to the same specs as your audio source.
You claim that LDAC is sophisticated enough so that, if left on its Default = 96kHz and 32bit on Android 13, then it can manage everything on its own without any artifacts.
Do you have any source(s) about your claims?
https://en.wikipedia.org/wiki/LDAC_(codec) ..
Only Sony knows how they manage exactly their hybrid coding scheme based on the modified discrete cosine transform and Huffman coding .... But, I never seen any measurements showing that to select manually the source format bits or frequency is better than the automatic selection by Sony's codec while reading the file..
For sure with many of my devices and Bluethooth Codec Changer android 's app https://play.google.com/store/apps/details?id=com.amrg.bluetooth_codec_converter&hl=fr&gl=US, I can easily make a direct A/B comparison with profiles based on AAC vs LDAC and LDAC at 330kbps vs LDAC 990 kbps.. But 44.1khz vs 96khz on a 44.1 khz file => absolutely ZERO impact for sound..
Try by yourself with your own ears, it's very simple..
