Dobrescu George
Reviewer: AudiophileHeaven
Please quantify this. I also have both - and the answer is ..... it depends on.
For example - and these are the first ones I thought of.
- Which module the Q5 has, and what headphone you're using
- Your personal taste in tonality
- How you want to listen to your music
- What you value in portability
In terms of sound quality
- if I prefer to have a more minimal and more portable experience, I might find the X5iii or the M9 better than a Q5 - as then I don't have to carry a source device as well.
- if I prefer to have my phone decoupled from my music - then the choice is obvious and its not the Q5
- If I'm listening to IEMs and don't need the extra power, then it becomes a real choice (preference of tonality)
Saying one is better than the other is (IMO) quite silly. The answer is - it depends on what your preferences are. SQ is about the same.
- Both have distortion levels below our audibility thresholds
- Both have low impedance outputs
- Both have good SNR ratios and cross-talk measurements beyond our audibility
The better answer is:
I could go on - but you get the gist. Saying the Q5 is "much better" than the X5iii for Spotify listening - without quantifying context is at best misleading, and at worst totally incorrect. At least find out what the person values (attributes), then you can give them a more informed reply.
- If you're driving a harder to drive headphone the Q5 has better power options - depending on the module
- If you prefer a warmer, richer tonality, both can be viable options - but with the Q5, you will need a different amp module to achieve this
- If you prefer a more neutral sound, the Q5 has better module options to achieve this
- If you prefer a device to uncouple yourself from your phone - then the X5iii or M9 are better options
- If you prefer your phone's UI and just want better SQ than your phone, the Q5 is probably the better option
FWIW, I use Spotify, and have both the Q5 and the X5iii. They are both fantastic sounding devices. Unless I'm using the HD800S, Alara or HD300, 9/10 I'll either be using the X5iii or direct from my iPhone SE. If I'm using my full sized, and moving around the house - then I'd take the Q5.
Good points all of them actually.
X5-3 is less revealing than Q5 due to its lack in treble energy and smooth nature, so Q5 is more detailed. Of course someone might want that smooth / warm signature of X5, but I'm assuming that someone asking this question is asking about detail levels, where Q5 outperforms X5-3, regardless of which AMP module is strapped to Q5.
BTR3 is simply for portability, it doesn't have the detail, clarity, power, and refinement of Q5. BTR3 is a ~70 USD device and performs well for that price range, maybe using below 300 USD IEMs would make them more similar, but Q5 is considerably more detailed and revealing, has a deeper soundstage. I have reviewed BTR3 an the other BTR receivers for their price range, they aren't alternatives to Q5 or iFi xDSD, the BTR modules series are good for what they do, being ultra-small and portable.
My smartphone, Xiaomi Mi Max 3, is so far from either Q5 or X5-3, that I could never in my entire life use it for music, it literally struggles with IEMs to get me the volume I need without distortions.
Had the q5 barely 6 hrs. So far side by side listening vs btr1... Btr1 sounds more fun q5 sounds wider and shot of boring.
Do you have the same feeling if you are using bass boost on Q5?
Also, please try using Q5 wired instead of bluetooth.
