anmolkakkar
Where is the battery charge limiting feature on BTR7? I cant find it anywhere in the settings or in the FiiO control app.
Is your Fiio control app up to date?Do you mind sharing a screenshot of it? In my unit there is nothing like such in v1.85.
@FiiO are there different software version being released to different users? My machine is bought in India and has the version 1.85 as downloaded from the FiiO control app's "Online Upgrade" option.
I have the same issue when playing various mqa and non-mqa tracks from Tidal app on iPad Air 5 and iPhone 13 pro max.This is an interesting device. I received my unit two days ago and updated to v1.85. I am pairing it with am Iphone 13 and using a set of P1Max. When in wired mode, it makes a crackling noise when changing tracks for a 1-3 seconds. The crackling/distortion is mostly associated with the screen being on. When it is on and a track is changed, you can see the scree glitch a bit. This correlates with the crackling/distortion I hear. It also crackles at the beginning of some tracks even when the screen is off. Wireless performance is good and there are no issues.
Anyone else have the same experience in wired mode? I am seriously thinking about returning this and trying out a Topping G5.
I would like to use a portable DAC/amp in both wired and bluetooth modes. Any suggestions on other units that fit the bill?I have the same issue when playing various mqa and non-mqa tracks from Tidal app on iPad Air 5 and iPhone 13 pro max.
I also get crackling/static/robotic noises when switching app on S22 Ultra, when turning off audio and then turning off screen, and then turning audio back on in any app. But it is solved by re-plugging the C-to-C cable and it reappears when the same scenario happens. Very annoying.This is an interesting device. I received my unit two days ago and updated to v1.85. I am pairing it with am Iphone 13 and using a set of P1Max. When in wired mode, it makes a crackling noise when changing tracks for a 1-3 seconds. The crackling/distortion is mostly associated with the screen being on. When it is on and a track is changed, you can see the scree glitch a bit. This correlates with the crackling/distortion I hear. It also crackles at the beginning of some tracks even when the screen is off. Wireless performance is good and there are no issues.
Anyone have any idea what is causing the crackle?I also get crackling/static/robotic noises when switching app on S22 Ultra, when turning off audio and then turning off screen, and then turning audio back on in any app. But it is solved by re-plugging the C-to-C cable and it reappears when the same scenario happens. Very annoying.
Glad that I'm not the only one with the LDAC issue, but I have the original BTA30.Switched to APTX HD and it’s not happening so far.
Yea, it's been 3 nights using APTX HD and no resets. When I use LDAC, it happens at least once every night I use it. Sometimes 2 or 3 times.Glad that I'm not the only one with the LDAC issue, but I have the original BTA30.
Can't believe FiiO has not acknowledged this issue that is clear to be happening with this combination.
As you mentioned, using AptX HD doesn't trigger this issue.
I don't think the optical to coax will make a difference. I do believe it is an encoder or decoder issue either on the BTA30 or on the BTR7. With my LC-BT2 and my BTR5 LDAC works without issues. This is only happening in the BTR7.Yea, it's been 3 nights using APTX HD and no resets. When I use LDAC, it happens at least once every night I use it. Sometimes 2 or 3 times.
Here's what I want to try. I'm going to convert optical to coax with an adapter. Maybe the coax port gives me better luck? who knows.
I will say that APTX HD while more stable, doesn't sound as good as LDAC. Hopefully Fiio fixes this. If they do, this is a really nice combo to watch tv with using 4.4 balanced to my Sennheiser HD800s.
Chibs
