There's not much but I do notice the M11 Plus sounds wider while the BTR7 sounds more enclosed. It's slight but I do notice it. This is with my Elegias
Yes, battery could have been better. I recently went on a trip and for me, the battery only lasted for ~2 and a half hours. Admittedly, I was using a planar IEM (Hook-X) which requires a bit more power than other IEMs but still with 4.4mm Out @Low Gain & Boost set to "Off" I would have liked more battery life.
I ended up having to switch "On" the charge button which drained the phone's battery a lot but atleast I was able to continue listening to music.
Oof that’s interesting - I’m not sure how the timeless stacks up against the Hook when it comes to output power needed but I was listening to the timeless, 3.5mm out with the boost set to on as I clearly heard a difference between the two options and I was 2.5 hours in with 55% left With a listening volume hovering around 25%.
Pretty different use models and costs. Putting sound quality aside, how do you feel about carrying around a DAP and phone compared to a BTR7 and phone?
I got the BTR7 on Sunday, and the Shanling Up5 yesterday. So far the Up5 is looking much better:
- 3.5, 2.5 and 4.4 outputs cover all my needs for a portable DAC/amp
- a wheel to adjust volume, rather than push-button volume control
- sound quality close enough between the two; it’s hard to say which is ‘better’
- still enough power for ’phones like the HD6XX series
- a better ’next track’ / ‘previous track’ interface, common to other devices, rather than having to remember the BTR7’s idiosyncrasy
I’m tempted to keep both, but last gen I went through the same dilemma and ended up being happy with the Up4 and returning the BTR5.
I prefer FiiO as a brand - but I wish they’d address the above points with their products, otherwise it seems the Shanling keeps beating them for my needs & preferences.
Eh it's not that bad compared to the BTR7. My right pocket is normally empty so I put the DAP there when I'm out while with the BTR7, I can put it in my left pocket with my phone and completely ignore it. If I stack it with my phone, it's really noticeable. Tried putting on my shoes with it stacked and it kept digging into me. Don't really notice it after a while when out though.
If the BTR7 had a clip case where I could attach it to my belt, I'd probably notice not using it more. Will say though, it's alot easier finding the right buttons through your pants with the BTR7 than the M11
If you're used to carrying a battery bank, this is nothing.
Tldr, if you have a spare pocket it's fine. BTR7 is definitely more friendly on the go.
