hardbop
- Feb 16, 2005
I've been listening to the BTR5 for a couple days, doing some direct comparisons and settling in for normal listening.
My use case will be pairing with my 3.5mm jack-less Note 10+. My previous Samsung phones all had subpar sound quality from the headphones jack anyway. With LDAC the sound quality is a net positive. Since I've already upgraded to full size BT 'phones to circumvent the aforementioned headphone jack, I'll mostly be using this amp for my IEMs.
So far, I've run it with the Tin T2 Pros, Tin P1 and my custom JHA Layla's. As a cruel benchmark, I also pit it against my AK380.
The music I used for direct comparison was the beginning of Joanna Newsom "Occident"; the beginning and 1:40 mark of Holly Herndon "Frontier" and the 3 minute mark of Aldous Harding "The Barrel".
In general, the BTR5 has strong bass, if a little lacking in detail. The mids to upper mids are excellent and the highs are a little lacking. I'm not yet sure if it's rolled off or if the peaks and valleys of the frequency response are working against it. Sometimes the highs sound thin and other moments I can hear the clarity I'm expecting.
The T2 Pros, for example, can have its vaunted treble take a turn for the sibilant. As a trade off, there is a greatly increased bass presence. The mids and vocals still punch way above their weight class.
Similarly, the P1's have an excellently represented midrange and their strength is still with the vocals. The low end detail is present, but somehow not as authoritative as the little brother of the Tin lineup. Highs still sound rolled off, so maybe the amp doesn't quite have enough power. There's enough volume to listen comfortably at the 60% range and isn't ear splitting at 100%. I think it will still be adequate, but I'm not confident that there's enough to really get the planars going.
The BTR5 pushes my custom IEMs much better than any of my previous phones could ever do. It was usually too much a compromise to listen straight from my phone and would opt for lesser in-ears when isolation was required.
The general sound signature of the FiiO amp is confirmed with the overly critical Layla's. However, the pairing sounds fun with no major downsides, so it should be a happy medium for daily portable listening sessions.
The form factor and usability of the amp already works better and more conveniently alongside my cellphone than a entirely separate DAP or the USB DACs I've used. I'll have to experiment with the filters later and since I'm using LDAC, there's no EQ to fuss over. The rest of the UI has been flawless.
I can go into more detail, if anyone has specific questions. Otherwise, I can comfortably recommend the FiiO BTR5.
