[FIIO BT11] Portable High-Res Bluetooth Transmitter Is Officially Released!
Mar 21, 2025 at 6:23 PM Post #991 of 1,289
O
OK thanks a lot will try that if the FiiO page update fails, not that I will know probably just cycling the same "updating" screen...
Update: Off course the damn FiiO web updater crashed my computer, what else did I expect...
Iphone doesn't detect BT11 in bluetooth settings now I'm completely stuck...
Can somebody please explain the whole procedure, what I did is stuck BT11 in usb c port of my laptop, it got detected by fiio updater webpage, and then the screen "updating please don't disconnect" goes on forever...
On Iphone I cant even add the damn thing it doesn't show neither under bluetooth neither in fiio control app, so not much I can do to update on iOS.
Mar 21, 2025 at 6:48 PM Post #993 of 1,289
First of all, make sure that your bt11 is not getting paired to any Bluetooth device
Connect bt11 via usb to your iPhone
You should see bt11 when pressing “add new device”
When you added and open that bt11 and you should get popup saying something like paring request and you should click pair
Than you go to settings -> firmware upgrade -> local upgrade and choose 1.0.9 firmware you probably downloaded manually from link posted here before to your iPhone storage..
Mar 21, 2025 at 6:54 PM Post #994 of 1,289
Yeah exactly what I'm doing but get stuck on the screen below, after tapping add device I get next screen with no device listed on it...
Mar 21, 2025 at 6:57 PM Post #997 of 1,289
I didn't need to download any file manually. The iOS FiiO Control App immediately prompted for the update as soon as bluetooth connected.
Mar 21, 2025 at 7:07 PM Post #1,002 of 1,289
Than most probably paired automatically to your pc or android device
Try disabling Bluetooth on these devices
Nope disabled all still nothing, I'll try reseting the damn thing on my android phone
On my android phone it immediately shows upafter i forget, disable, remove pairings and delete the BT11
Mar 21, 2025 at 7:17 PM Post #1,003 of 1,289
One last try for today, sorry must go to sleep here, I’m from Israel and it’s late here.
Try keeping bt11 connected to your android and from iPhone try pair as you tried before.
Mar 21, 2025 at 7:19 PM Post #1,004 of 1,289
OK will do, actually already did bu doesn't hurt to try once more as the fiio web updater doesn't work anyway, can try with another iphone tomorrow if this doesn't work...
And hello and good night to Israel, thanks for your help :)
