[FIIO BT11] Portable High-Res Bluetooth Transmitter Is Officially Released!
Mar 21, 2025 at 4:39 AM Post #963 of 1,326
Mar 21, 2025 at 8:33 AM Post #964 of 1,326
Fiio - what are you doing, have you eaten too many mushrooms? It is impossible to update via Fiio Control - constant errors! Why do you write that Android owners can update via a web page? Then give instructions or admit that nothing works for you again!
Mar 21, 2025 at 10:30 AM Post #965 of 1,326
So the Android app received an update today (version 3.34) claiming the new support for BT11 functionalities that requires device FW update to 1.0.9. via iOS version of Fiio Control app. Has anybody tried it already? I have no Apple device to try. Or is there any other way via PC?
Mar 21, 2025 at 10:48 AM Post #966 of 1,326
just completed the update via my iPad. Correct version number is now visible
Mar 21, 2025 at 10:56 AM Post #967 of 1,326
Windows and Android owners have been brazenly deceived again! Fiio claimed that BT11 would work with IOS, Android, Windows and everyone paid money for this product. But for some reason Fiio forgot about Android, and their buggy Fiio Control for Windows doesn't work!But what efforts are spent on radio receivers and cassette players!
Mar 21, 2025 at 1:21 PM Post #969 of 1,326
How did you upgrade this? What steps?
I press online upgrade, then it download FW and then nothing happens. Only black display
I had the same on my iPhone, only black display. On my iPad the online update process ran correctly.
Mar 21, 2025 at 1:48 PM Post #970 of 1,326
Did your BT11 work smoothly after update? My update went fine but with this “proper” v1.0.9 I have all the symptoms of “draft” 1.0.9 - not possible to select codecs, not entering pairing mode, etc.
Mar 21, 2025 at 2:00 PM Post #971 of 1,326
Does anyone have the 1.0.7 .bin file to downgrade with? Updated my BT11 to 1.0.9 using my iPad and now it won't pair with anything :(
EDIT:
Figured out I can just download the .bin file from the FiiO Control website. Downgraded and the BT11 is usable again.
Mar 21, 2025 at 3:13 PM Post #972 of 1,326
Pair management and codec selection including new features such ldac 330/660/990 kbps are only available with updated android app version.
If you have only iPhone you’d have to wait till iPhone updated version Fiio app release
Most probably under apple App Store verification since every iOS app has to get verified by apple before published, android is more fast at publishing..
Mar 21, 2025 at 3:22 PM Post #973 of 1,326
Pair management and codec selection including new features such ldac 330/660/990 bit rates are only available with updated android app version.
Thanks, that was my thought as well.
Mar 21, 2025 at 3:23 PM Post #974 of 1,326
I upgraded to 1.0.9 using my iPad and was successful. Using the FiiO Control app on Android (no iOS update yet) the settings seem to work fine. No extensive testing but 909/990 LDAC seemed to work as expected on my FW5. With my MTW4, AptX Adaptive/Lossless is not stable, sound drops out after a minute or so and eventually stops altogether...
Mar 21, 2025 at 4:09 PM Post #975 of 1,326
It takes some balls to udpate the app on android and say you need ios to even use the features LOLOL. As far as I understand Fioo literally said update via android will never happen. Also is there still the possibility of updating via PC?
