1.2.17What is the currently available (latest) FW version?
[FIIO BT11] Portable High-Res Bluetooth Transmitter Is Officially Released!
- Thread starter FiiO
lairpost
The app is 1.2.17. BT11 fw is 1.0.71.2.17
Petru
- Dec 12, 2011
@bqqhuy , please tell if LHDC ONE gave you better signal stability in comparison to BT11?LHDC One
I also found at least 2 versions of LHDC ONE: one from TempoTec and one from Savitech Corp. They look very similar, so it seems like almost the same product.
My iFi Go Pods support both LDAC and LHDC, so I'm down to get best signal stability possible as intended to use on the go.
skfktkwjs
- Nov 17, 2011
Is it true 1.0.8 update is delayed to the end of Jan 2025?About BT11
We plan to implement these features in the 1.0.8 firmware, which is currently available,
but there are still some bugs that need to be fixed and some time is needed
Please wait a few days
rookieaudioenthusiast
I hope not. Fiio Wilson said on Dec 17: “Is it true 1.0.8 update is delayed to the end of Jan 2025?
About BT11
Please wait a few days.”
FIIO distributor's Twitter account (Dec 27) :
Regarding the firmware update for BT11.
At this time, we have received a notice from the manufacturer that the firmware update will be released in late January.
We apologize for any inconvenience this may cause in terms of connection stability and LDAC connection.
(machine translation)
source : https://x.com/FIIO_Japan/status/1872525530668613682
擁有三星 S24,因此他可以使用手機使用 LDAC 並隨時享受他的 1More Sonoflow 耳機。
我買了 BT11 來搭配他的筆記型
https://www.head-fi.org/threads/fii...icially-released.973855/page-38#post-18441276I bought a BT11 for my son as a Christmas present. I read about the problems so I tried the device before giving it to my son.
I inserted to my Xiaomi 12 phone and as suggested by Fiio tried to use the Fiio Control app to connect the device but I failed several times.
I wanted to use it with my own 1More Evo TWS.
After this unsuccessful attempt I read in a forum that Bluetooth shall be switched off and after inserting BT11 to my phone the holder of my TWS should be opened
and put as close as possible to BT11. And at this moment BT11 was able to connect with my Evo!
That means the BT11 started to pulse in Blue colour and I was able to listen to music using USB Audio Player Pro app, but I was unable to reduce the volume
from that moment and it was very loud.
Anyway my son has a Samsung S24 so using his phone he can have LDAC and enjoy his 1More Sonoflow headphones anytime.
I bought the BT11 to use it with his notebook which normally has a very week sound (even the better notebooks).
So I inserted the BT11 to my Lenovo Yoga7 notebook and it worked well listening music from TIDAL.
In TIDAL I selected the "Headphone 2 Fiio BT11 (UAC 1.0)" option and after that I went to the feature settings menu of this "headphone", but I was unable to chose
any Bluetooth codec. I chosed in the settings Studio Quality (24 bit, 96000 Hz).
The music sounded pretty good, however I did not know what codec the BT11 was using.
Theoretically Blue means SBC, but it sounded much better than that.
Do you have any suggestions how my son will be able to use BT11 with his WINDOWS laptop using LDAC?
Is there any FIIO WINDOWS app to adjust the Bluetooth codec? If not how to chose LDAC on a computer?
Many thanks in advance...
lairpost
Fingers crossed for FW release just before CNY. BT11 has been working great for me with iOS. Hoping for LDAC 990kbps to see if there's any audible difference from 660kpbs, unlikely but since range is a non-issue for my use case why not use the biggest pipe to ensure it's not the limiter.
Wrong device!
lairpost
Thx but I'll wait for the official release.
Well, the post was from an official release, and not from my own doing or anything
lairpost
Yeah, the version numbers didn't jive at all. Searches for BT11 turn up lots of BTR11 results.Well, the post was from an official release, and not from my own doing or anythingIt was just not for this device actually.
scracy
Is it just me or are @FiiO releasing a lot of products lately that just dont work? Great hardware and awful software/firmware that is getting worse with every product they release.
And where are the promised fixed firmware for Android and Windows?
Towards the end of this month? I think I read something like that.
