Mooses9
- Feb 12, 2009
These stupid cables damaged my w4rs their pins are not consistant and and i noticed on them that what was consistant was one pin was longer than the other and that not only that the pins had a larger circumferance than the stock cable and was spaced farther apart. So when i tried to push the cable in and felt resistance i thought well the stock cable has some resistance they have a tight fit. No it was that these cables were thicker and spaced farther apart. Which in turn. Alongated my hole for my cables.
I should have never and would never use these cheap pieces of garbage ever again. Nor would i reccomend fiio to anyone not for a amp or these crappy cable this took the cake.
They obviously have no quality control at all whatsoever even if the pins werent spaced out they would have never fit they were too thick. Not to mention what was with one pin longer than the other?
I give them 0 stars out of 5 and if we can do -0 out of 5 i will give them a -5 out of 5 pure crap they are putting out.
Like i said i normally stick to high end. And i will never stray from them again per i never seen such poor quality in my life jesus.
NOT TO MENTION I HAVE HAVE A FING ENLONGATED PIN HOLE IN MY WESTONE W4R FIIO THANKS A FING LOT!!!!!!!
