#FiiO 2021 Autumn New Products Launch Event IV# will straightly get to you on October 26, 2021. Let's stay tuned for it.
Oct 26, 2021 at 7:44 AM Post #61 of 72
The M17 has smooth smartphone-like performance thanks to the Snapdragon 660 SoC and open Android 10 OS with Google Play support to install 3rd party apps. The USB receiver chip is the XMOS XUF208 which supports up to 768kHz and DSD512. The new-gen flagship QCC5124 supports aptX Adaptive, making for a Hi-Res audio experience even when you are hanging out.
Oct 26, 2021 at 7:45 AM Post #62 of 72
Since the M17 has ultra high power consumption, the large 9200mA battery capacity only allows a continuous playback for about 10.6 hours under single-ended output, and about 8.6 hours under balanced output.
Oct 26, 2021 at 7:49 AM Post #63 of 72
As the blockbuster of the year, the M17 surely comes with abundant sets of accessories- a cooling stand with fan + an external DC adapter, a leather case, a USB 3.0 data and power cable and an aluminum alloy dust plug. These cover a wide range of scenarios in your daily use.
Oct 26, 2021 at 7:53 AM Post #64 of 72
Enjoy desktop-class sound quality in a portable size. The #Portable Desktop-Class Player M17# only sells 1799.99 USD (US market). For more introductions and information, please follow us to check.
This is all for today's launch event. Thank you so much for your attention. See you next time>>~
Oct 26, 2021 at 2:28 PM Post #65 of 72
Noticed HiFigo is offering pre ordering at $1999 whilst fiio state a price of $1799. Anyone pressed the button yet?
In addition, I've held off from buying one to see more comments from members regarding the released build details. Those RGB lights... really?.... they don't automatically change according to the sample rates played like A&K... they are just .... lights... mood lights at that... 😳 and as they are just... lights.... I hope they have an option to turn off completely as this will save power and also any possible electrical interference as I'm familiar with this on full size audio equipment when displays are turned off the music is not disturbed by interference. I take it the batteries are not easily or conveniently replaceable? The images show a cage like case fitting over the rear... is this easily removable to gain access? 🤔
Oct 27, 2021 at 6:09 AM Post #67 of 72
In addition, I've held off from buying one to see more comments from members regarding the released build details. Those RGB lights... really?.... they don't automatically change according to the sample rates played like A&K... they are just .... lights... mood lights at that... 😳 and as they are just... lights.... I hope they have an option to turn off completely as this will save power and also any possible electrical interference as I'm familiar with this on full size audio equipment when displays are turned off the music is not disturbed by interference. I take it the batteries are not easily or conveniently replacable? The images show a cage like case fitting over the rear... is this easily removable to gain access? 🤔
You could set its colour to change according to the sampling rate in the M17 as well. And yes, the light could be turned off.
Best regards
Oct 27, 2021 at 7:16 AM Post #68 of 72
Best regards
Excellent! Final questions answered which is brilliant customer service. Thank you. Order for the M17 now placed. Cannot wait to receive it.
Oct 27, 2021 at 11:50 AM Post #69 of 72
@FiiO You have a stand with a fan, why is this fan needed? Would it be that it’s not as efficient dissipating heat laying flat versus on the stand at an angle?
What‘s the max temperature the unit is clocking in? Can you safely (temperature wise) run the player on a stand without the fan?
What’s the noise level added by the fan?
Oct 27, 2021 at 3:06 PM Post #70 of 72
Has anyone purchased a DAP from the Fiio EU offices which sends DAPS from Bulgaria to the United Kingdom? Have you encountered any additional costs such as VAT &/or import fees?
I bought my M11 Plus from HiFiGo, got it pretty quickly in a week or so to the UK. They cover the import fees if Yunexpress shipping is chosen.
Oct 28, 2021 at 3:29 AM Post #71 of 72
With exceptional audio quality comes large power consumption, so effective heat dissipation was a large focus when designing the M17. Not only are "H" type heat dissipation and VC liquid cooling technologies adopted, the M17's 151g unibody aluminum alloy frame also effectively transfers heat out of the device. Finally, the cooling fan stand also further makes sure heat is rapidly transported away.
Genreally, the fan is not needed.
And the sound of the fan is not noticeable in level 1.
Best regards
Nov 3, 2021 at 6:37 AM Post #72 of 72
ETA of my M17 is 10 days... can't wait!
Countdown begins....
