myemaildw
- Jun 10, 2014
I'm almost certain I wouldn't be able to tell the difference between a high quality MP3 (about 256kbps or higher which has frequency cutoff at a minimum of about 19kHz according to Spectro) and a lossless file. I will absolutely do my best to have the lossless version, but not because I can hear the difference. More to just be happy seeing all the frequencies are there even if I can't hear the difference.
I like to think that we can reside in both camps. Yes in the portable world, I tend to plug my IEMs into an iPod Touch 5G, high-end or not (this iPod has seen crap like Skullcandies to shining examples like the 1964 Ears ADEL U-series, universal versions of the A-series). The source, if decent enough in the case of today's better smart devices, matters less than the IEM when on the move in my opinion. Would a higher end source immerse me in the music more? Probably. But am I still having a great time? Absolutely! I know it can sound better and I've heard it sound better, but I get quite a bit of enjoyment as is and you said it right, if you enjoy it, by god stick with it!
I definitely also reside in the camp of hi-res through the entire chain as well. I understand your logic; once you start picking up a deficiency, be it in the mastering or in your playback equipment, it starts to get annoying to notice it more often. My desktop setup has music that is preferably at least 256kbps (or 18+kHz frequency cutoff on Spectro) or higher, run through a dedicated DAC and amp (listed in my profile if you'd like to know, I consider to be a great budget setup that does everything I need it to), and to a quality set of bookshelf speakers (which I also just upgraded to a new set). With that setup, it's easy enough to start a playlist, lay down on the bed, and just melt away into a world of bliss.
Also, I MUST commend you on being one of the better people on the internet, much like what can be said of many other members of Head-Fi. You acknowledge and accept that not everyone may share your view instead of blindly shoving your own opinions down others' throats in a very subjective hobby. So cheers for that, you've made this corner of the internet a nicer place to be than many others
I can tell a difference between even highest quality mp3 which is 320 kpbs and 16 bit which is 1000 kbps or cd quality. may be because im a bass head and most difference is in bass quality and bass quantity. i can even tell a difference on my low gear. but surely mp3 s aint that bad, they are quite good, and i mostly have flacs on my favorite songs, cause flacs are too big
