friedrice2307
- Jun 7, 2015
Someone should invent gel tips that conforms to your ears like comply foam tips but gel.
Sent from my SM-N900P using Tapatalk
Hmm. So I wonder if UE900 tips are the same as 600/700?
This is what the UE700 tips look like guys.
I think this is them here. (I think)
http://www.ebay.com/itm/GENUINE-Ultimate-Ears-Tips-Comply-Foam-Tips-Clean-Tool-for-Most-UE-Earphones-/250951842489?pt=LH_DefaultDomain_0&hash=item3a6de53ab9
Also try looking for some of the cheaper (cheapest) UE earphones, they also include them and are around $15 to buy.
Ah! Those look like the Tips on my UE900, but in a dark grey colour. I shall try them out.
Thanks!
I've just put on the UE900 tips in place of the JVC ones I was using and got, a little tighter bass, a bit more clarity, and smoother highs, just as you mentioned H20. The sound quality has moved up a notch!
Thanks again for your suggestion.
Silicone tips never seem to work for me. I'm not sure why but every time I get a new pair of IEM's I try them but no joy.
Just got a pair of the A83 from another head-fier. I'm definitely really happy with them, only problem being that darn cable! Fortunately, I had another one laying around that I could try, but I really wish I could still use the Fidue one, since it looks really cool. Has anyone tried reterminating the connectors with some normal or curved Shure ones? I can't imagine it would be terribly difficult, and I would think that it would work. Has anyone done that yet? Also, I'm trying different tips, anyone know of anything that can give better isolation? I have a sneaking suspicion that the Dynamic driver is the cause, and therefore unfixable, but if there's anything that can improve isolation, I'm all ears! (I have a pair of double flange tips that I swapped out with the single flange ones, and they don't really make a difference to isolation, to my ears at least.)
The answer might be Sony Isolation tips. Silicone outer, foam inner. Longevity plus great fit and isolation.
Definitely the best solution for isolation via tips (at least that I know).
I'll have to look into them then!
As a test, get some couton and place it inside your tips. See how much it isolates. Sony Isolation tips will isolate pretty much the same with the foam inside.
Will do! Thanks for the tip (pun not intended?) Never thought to try that before!
