UntilThen
- Jun 16, 2015
I have always used 2 C3g. Not sure if running just one will be okay. Perhaps @2359glenn can clarify. My OTL cannot use 6SN7 IIRC.
Ah ha... looks like our amps will be different.... base on this...
Two C3g sockets plus 6.3>12.6>25.2 volt switch for the SN7 socket you can use 6SN7 , 12SN7/B36/FDD20 with adapter
and the 25SN7/1633 or the 13D1 that is a 25SN7.
That seems to me that mine will have 2 C3G socket plus one socket for SN7 with a switch for 6.3 > 12.6 > 25.2 volt. So that means I either use the C3G or the SN7 but not together.
@2359glenn can you enlighten me. Thanks.
