optical, co-ax and USB would have made for more possibilities and made it easier for me to connect to more sources.
That would have made it a DAC+amp, quite a different animal.
Connection of coax USB Optical parts for imports does not make it a dac
That's true, but to get sound from the amp it would have to convert the digital signal from those digital inputs to an analogue signal, as I understand it.
Hi H-E-A....externally, the quality is very Elise-like - ie. very good! The case size is the same, but with the front plate slightly larger and the finish a tad less matte than the very first Elises (and so not quite such a dust collector lol!). The transformer housing is larger than my prototype Elise, but am not sure if this is in fact also true for the later units. However, I believe F-A have also 'beefed up' the housing somewhat.
However, internally, there is indeed quite a jump in quality, along with certain design changes even though the general layout remains similar :
And so, having the same case size, I suppose extra inputs and outputs wasn't really a viable option in F-A's eyes. And at least the one (extremely good!) pre-amp out is enough for most folks lol!...
From the internal views it seems we are talking about two different amps. Oh, I guess we are
I hope externally I will be able to tell them apart visually because they are going to sit on my desk side by side. Twins !
@hypnos1
Sorry to repeat myself, but do you ever have any desire whatsoever for a better sounding amp.. or any inkling that there may be something better out there, or is this seeming to be your end game?
Also if you had to compare the Euforia to the Elise, how much better would it be percentage wise... or if not by percentage could you at least use a superlative adjective, such as a lot better, much better, vastly better, mesmerisingly better, etc.?
No comparison to the two is legitimate (in my view) unless the comparison is preformed in a blind fashion.
I guarantee you that knowledge of which amp your listening to, will horribly prejudice your opinion of what you think you hear.
Hopefully someone who can afford both amps, rigged with an identical tube compliment of choice also has a knowledgable friend avail to conduct a truly blind test.
My attendance to a mini head-fi meet where blind tests were conducted really opened my eyes (pun intended) as to how good top notch SS gear performs, compared to top notch tube amps.
If the Elise. vs Euforia comparison is not conducted totally blind....I would kindly dismiss any expressed opinions.
Cheers!!!,
