w
The usual:
@Deyan here or MrsX on eBay. Make sure to specify that they are for Euforia, and not Envy. Euforia can actually use a single triode per side, so you don’t have to use dual KTxx, 6J5, etc in each tube spot.
I probably have a few (2-4) 6as7/6sn7 to KTxx adapters available, and a few matched KTxx/xxx pairs that I would sell, from my Euforia times.
The nice thing about Euforia is that you can use matched pairs instead of quads of single triodes, and triode strapped pentodes and tetrodes.
You will have to be careful that you don’t exceed the rated heater current for driver and power tubes on the amp. You can easily cheat this, by using powered 6SN7 socket savers, which you should get from
@Deyan.
