dpeterfy32
BannedWARNING: INCOMPLETE CLASSIFIED SALES
I plan to buy a musician audio aquarius dac device for the euforia evo, what do you think? do you give everything to euphoria?
Hello,Hello everyoneI just bought a Feliks Evo, European version but I'm in Canada! I have a few questions and was hoping somebody could help me out
Would I need a downstep transformer? If so any recommendations? Is giving it to an electronic shop to switch it internally a better idea?
-Secondly, what does "230V" and "120V" mean on the back of the Evo? I doubt that it means the amp can be used with both 230v and 120v power outlets without any modifications or a stepdown transfromer?
Super duper excited to fianlly pair my Aeolus with a proper amp after 4 years.
Yes, that explains a lot.Sorry the red arrow isn't my drawing. It's just a snapshot from a youtube video. I just meant to show the back of Evo and find out what those "230v and 110v" mean.
I know I have a 230V version. It's brand new and being shipped from Germany.
" if you know this, the fuse must also be changed accordingly."
.Do you mind explain what do you mean by this? Is the fuse inside the amp and needs to be changed?! I'm as uneducated as they come when it comes to electrical stuff, and English being my 2nd language is not helpful either
Thank you for your help![]()
Thank you. I doubt the seller would agree to ship it to Feliks and then Feliks to me since I got it on ebay. Will ask him anywayYes, that explains a lot.
What I don't understand is why do you buy a Eu version when you have a Us network at home?
The Euforia doesn't have a separate switch where you can set the AC voltage.
It has to be opened and the transformer has to be re-soldered accordingly or even a new one has to be installed that is designed for 120v.
You definitely have to ask Felkis what is possible.
You can try a downstep transformer, but I can't answer whether you can use the Euforia hum-free.
That would be an additional question for Feliks.
As for the fuse, you only have to replace it if it has been converted to 120v.
If you use a downstep transformer, you don't have to.
The fuse is located at the Iec connection (power connection from the Euforia) there is a flap that has to be levered out with a small screwdriver.
In the end it would be better to buy the Us version and not the Eu version, this would cause the least problems and would be the easiest way.
I don't want to stab my compatriot in the back, who is obviously a chef, but he should have known and said so out of kindness.
Which he probably did or you wouldn't be here.
It's not necessarily a deal I would have entered into personally, because there is some money involved, and a German advertisement once said that you don't play with money.
The other option would be to buy it but contact Felkis first and ask them to convert it to 120v.
If it works out, ask the German seller to send it to Poland and Felkis to send it to Canada.
That way the costs would be more or less manageable in terms of shipping.
Shipping the part from Canada to Poland will cost something.
Then you don't need to consider a downstep transformer and other things.
Hi SMF.
mordy and connieflyer have already given you very good answers...and as cf mentioned, a lot will depend on whether it happens to different tubes, as opposed to just the same one. Some tubes (of the same type) will often have a different glow, as stated.
As this glow comes purely from the heater (anywhere else and you've got big problems!), try 'approved' tubes and see if the same thing happens...and if it does (with several tubes), then it would indicate something amiss with the amp's heater circuit, and would probably need looking at by F-A...(not very likely though!).
I personally would only be concerned if the tube's heater glowed really bright...especially with these particular tubes. Or if the plate started to glow (very rare, thankfully), most probably indicating that the tube needs to be replaced immediately!!
Hopefully it's just variation in certain tubes lol...
Anyway SMF, getting back to your own findings re. this family of tubes, I see you like the 4x ST combo. Do you have any of the smoked glass CV1052 at all? As I mentioned previously, my system much prefers this version, and I can't recommend it highly enough. I am more excited even than before, as one of my original 4 (not one of the 3 for £8!) was obviously not functioning 100%, despite supposedly being NOS and measuring strong in all parameters (but no original packaging) - it has already developed serious problems and would have gone straight back, had I not adapted it lol!
But now replaced by another (even using my own adapter, as opposed to adapting the tube directly), the sound is even better...and surpasses anything I've had before by a bigger margin yet!!...This is one very happy bunny, lol...
And so I'll post once again what folks who are interested in this tube family might want to keep their eyes open for...perhaps more will surface in time - I sincerely hope so!! :
These are specifically for British military use originally (note the arrow etched in the glass), and in their 'cigar' wrapping, with original box...amazing condition for such an old tube. And the glass is 'smoked'...it would appear that this coloured tube performs rather better than the clear ST EL32, and for me, much better than the later straight-sided version. But as usual YMMV!....GOOD LUCK!!...CJ
Hey Ut. Good to talk to you again. Sometimes I think I'm insane chasing my audio dream. Then I think of you!
LOL
OTL amps in general are poor at running low impedance planars, but the very sensitive Meze planars on Euforia seriesHi..
I am choosing a tube amp for my Meze Empyrean, DAC TOPPING D70s .
I have two favorites:
MCINTOSH MHA200
VS
Feliks Audio Euforia Evo
What do you think is the best choice - for jazz, vocals, pink floyd etc.
To handle Empyrean well. Have enough energy.
And what about price of tubes?
Thanks![]()
Yes, I am now sure that my headphones will probably be very suitable for this amp. Now I just have to compare with the Macintosh and choose the best for my ears, the feel, but also in price/performance ratio.OTL amps in general are poor at running low impedance planars, but the very sensitive Meze planars on Euforia series
are the rare exception. Feliks factually advertises this as a good combination, and it is, though it is still a bit better on a high end SS or OTC amp.
Hello,
You cannot connect the Evo to the Canadian mains if you have a 230 V version.
You need the downstep transformer mentioned above, which converts 120V to 230V.
I bought one on Ebay for a Japanese toaster.
It's not the same but I would try it if your information is correct.
The red arrow is the crossfeed circuit that has nothing to do with the mains.Is a sound thing.
You must now clarify what version you have, 120 or 230 volts, if you know this, the fuse must also be changed accordingly.
What surprises me is that you have a black dot at 120 V, if I look more closely I see a white X where something has faded.
I would ask Feliks what version it is based on the serial number on the bottom and what your options are.
If you bought it used, I would find out what has been done to it to avoid further complications.
And what further measures would be necessary for stable operation.
I hope this helps.
@tomina666 I would go with Feliks Audio Euforia Evo but keep in mind that this will probably result in you wanting Feliks Envy so badly eventuallyHi..
MCINTOSH MHA200
VS
Thanks![]()
Thanks a lot! The Macintosh is beautiful, a legendary brand... But the Feliks might sound better. I'll have to take a trip and try both amps at once. I'm just a little afraid I'll want a better dac than the Topping.@tomina666 I would go with Feliks Audio Euforia Evo but keep in mind that this will probably result in you wanting Feliks Envy so badly eventually
One of the best synergy I got with Empys with similar to Evo price tag amp is solid state AuroraSound HEADA. Amazing headphone amp almost like designed for Meze Empys, esepcially when paired with R2R or Chord dacs.
