ThanatosVI
You should use a 1 6A fuse.Hello,
Congratulations and welcome to the Euforia Club, you 2.
Have fun with the Ae and Evo.
I use the Linlai every now and then and am always surprised by how profoundly they perform and I also agree with the shot of warmth and better bass definition compared to the Ps vane.
You don't have to worry about burning in.
The Ps Vane unfortunately have a bit of a tendency to be strong at times and weaken again in the burn in phase.
So far I have only had this with these tubes and no others, not even in the Nos range.
It is actually more important that the Euforia should not run for more than 8 hours at a time, and in summer make sure that there is enough air circulation.
By the way, I have a question for those who have been here for a while.
On the back of the Euforia OG it says that I should use a
1.6 A T fuse.
I used a 1.25 A T fuse as standard, and I also used the same value for the Hifi Tuning Supreme 3 fuse.
Since I will be testing another fuse from a different manufacturer, I have to ask myself whether I should use a 1.25 A or 1.6 A T fuse.
Using a 1.25A instead will never harm the amp, since it will blow earlier than the 1 6A would.
It's possible that the 1 25A fuse will blow even tho the amp is operating as intended, depending on how tight they measured it.
You should NEVER use a fuse higher than 1.6A since this coujd potentially harm the amp by not blowing the fuse when needed
