Hello,
Thank you for the kind information.
They will be in touch when the amplifier arrives and everything is repaired.
There was no more information exchange.
I also think that he did not want to commit himself without looking over it.
Which is perfectly fine.
And I assume that Feliks has probably already found a solution.
Or already know one and will then gradually replace the component, possibly even with a more robust one.
The communication was kept short, probably for time reasons, but everything was within the framework and totally uncomplicated on their part.
So I have complete trust in them, and they also wrote their own instructions and not system-based ones like the big manufacturers.
That is also commendable.
Also your statement that they stand behind their amplifiers, that's exactly the feeling I have.
That has become rare in the meantime.
The appeal of the Ae would be there and I thought about asking if they would keep the Euforia and send me the Ae for a surcharge, or if they would convert it to Ae, but in the end I let it go.
To my ears, the Euforia sounds just right with the tubes, so I thought I'd leave it as it is.
I also lacked a bit of comparison, so I might have regretted it.
Otherwise, I am really satisfied with the little beast and enjoy it very much, especially with the Lcd2 C.
I don't want to overestimate the failure too much, it happens even to the best manufacturers like Macintosh.
They also allegedly have problems with the volume poti and deliveries.
It's a bit unfortunate because it's currently cooler outside in terms of temperatures, but I'll have enough days like this.
I'm looking forward to holding it in my hands again and enjoying the music.
And I know that everything is OK so far.
I ordered a cable from a manufacturer where the 6.3 jack will stay in and the other end of the cable has a 6.3 mm input.
This way, the jack can be protected a little better.
I have also ordered socketsavers and the increase in height will probably also reduce the heat on the circuit board a little, I think.
And about this cooling plate that the forum member posted the other day, I'm still thinking about whether I'll buy it.
There were very helpful tips and suggestions here from some forum members that I took to heart, thanks again for that.
