Have to agree with CJ. When you buy from an authorized dealer you often pay a few dollars more for them, if you look for a dealer that Burns in his power to choose and test them after burn and and matches them up so you know that hes checking the tube and writing down the qualifications on the tube it may cost you a little bit more but it will save you a lot more in the long run. Using the KT66 and the KT88 that I purchased from upscale audio I have not had one hint of trouble with them. Plus I know the tubes were checked and burned in and guaranteed. Upscale audio in the US is 1 of the largest tube distributors in the country. The to manufacturers know that when he orders in large number of tubes that he is going to go through each and every 1 of them and any badd tube is going to go back if he finds the manufacture that sends too many bed tubes through he won't buy from them anymore. He is an artist and easy to deal with distributor and I found over the last year that he is honest and does what he says his word means something. Plus you have to figure Felix audio trusted him to be his US distributor. They had to do a little bit of checking to get that up. But good luck, any time you buy a pig in a poke you get what you get
Well said cf...the more I ruminate on that JAC article re. the KT88, as far as I'm concerned it raises almost as many questions as answers given lol!
For example, there's no mention whatsoever of performance details and/or comparison between different makes of tube. And as for boldly stating that the GU50 is 'better' than the (GEC) KT88 anyway - again with no mention that this will depend greatly upon each individual amp's circuit design and quality of construction, I'm afraid this sort of thing leaves me less than impressed! I have indeed seen some positive reviews from DIYers re. the GU50, but also an aficionado who was comparing this with the 300b and who stated the KT88 performed 'better' (than the GU50). So as usual, not so cut and dried lol!
Plus, his own rubbishing of the Russian reissue Gold Lion contradicts the findings of a good many users, as mentioned previously...not to mention us here!!
Then there's the vexed question of the meanderings/ramifications re. the demise of the Svetlana/Saratov/Reflektor factories...especially when the New Sensor Corp became involved. The whole sorry saga would appear to be far more convoluted/complex than the JAC article would have us believe...again, a case of incomplete reporting that doesn't impress me either I'm afraid.
And so once again, my personal advice to folks is to do one's own research - as extensively as possible - into different sources of information related to any particular item, be it tubes or amps lol! And then, most important of all...trust your own ears...regardless of what anyone else says!!!
ps. @mordy , given the GU50 might just be an interesting tube to try, and I'll have my 12V heater supply ready, their peanuts cost has tempted me to see what they're about...but thought I'd finished with this tube journey to tell the truth!! Ah well, what can one do lol??!! ...CJ
Edit : pps. This experiment should be doubly interesting, given that if the GU50 is indeed "better than the KT88", I'm sure a good few KT88 lovers (and there's obviously many of them lol) would be keen to try the dirt cheap GU50 and save themselves hundreds of pounds/dollars...especially as different biasing would be easy on many of the amps used and (cheap) converters readily made to order from China??...time will tell...
