hypnos, I can attest to different cables. I was using a Moon Audio Blue Dragon USB cable from computer to Yggy. It sounded great! I then bought a Pangea USB cable. Slightly less bass and more detail. Why? It shouldn't be!
Hi triggs...and perfect timing for such an observation/query lol!!
Why?....because I myself have just had what I regard as another mini-revelation, with interesting (IMHO!) ramifications for digital cables that are so often overlooked when upgrading other cables and system elements.
USB digital transfer of sound is fraught with possible degradation/interference, and usually demands some fancy - and expensive - remedies. Which is one reason why I always prefer
coax digital function.
Anyway, my recent experiment using Neotech's OCC silver/gold alloy wire in my DIY coax cable, as opposed to solid pure silver (
not OCC), has finally answered a nagging question I had in my mind after hearing A11's HD800s cabled with said alloy wire...ie. that although it brought more upper mid and treble detail, along with a wider soundstage and smoother overall presentation, I still felt deep down there was a certain something missing. It seemed to me there were some very subtle frequencies not present, and which reduced the 'bite' I prefer in my T1s over the Senns (that Olli thought might be due to extra 'distortion' from my amp, which is what tubes do, of course!).
However, with the aid of now being able to do fast A/Bing of my two coax cables, I discovered that it
is indeed down more to the
wire(s) used! And the best indicator turned out to be three male voices - JD Souther's 'The Sad Cafe' & Jimmy Webb's 'P F Sloane' (in hi-res, from HDTracks download '2013 Sampler', which is free and can't recommend too highly that you d/load ASAP!), plus Bob Dylan's wonderful rendition of 'I Cross the Green Mountain' at the end of the music soundtrack from 'Gods and Generals' (which I highly recommend also!).
All these voices - but especially JD Souther's and most of all Bob Dylan's (whom you'd never actually recognise lol!
) - have (or
should have!) a certain rough
gravel to them which adds a special, unique character. And although the OCC silver/gold wire is deliciously smooth...
that gravel is almost absent!!! ...whoa!!...As is also indicated in Cassandra Wilson's 'Another Country' from the same sampler...her sexily smoky voice not being quite so
smoky lol!
And so, therefore, this would explain the additional slight reduction of subtle tones/overtones in instruments also, thereby minimising the 'bite' I've so come to love...an unfortunate side-effect of delivering such a seductively
smooth sound.
The answer?
Hopefully, by adding some
solid silver OCC wire to the mix...I
must get that gravel back!! (the other benefits of Neotech's OCC silver/gold wire are too good to lose). So it's back to stripping another length of cat6e cable, and the fiddly job of having to terminate one end with a BNC plug for the Naim and a 3.5mm jack at the other for Hugo2...(RCAs are much easier lol!!
The final conclusions therefore are that not only
digital cables are more important in the signal line than many may think/believe, but also that the very wire used can have quite noticeable effects on the final sound. The
degree will, obviously, depend very much on the quality of the entire rest of the system - from the mains electricity supply, thru other cables, to headphones - and the resultant level of resolution...not forgetting one's
hearing, of course!
...CHEERS!...CJ
ps. Will let y'all know if I do in fact manage that almost impossible task of getting
all those goodies I crave...gravel included!!
