H, just wanted lt let you know, after taping up the offending micro phonic-noisy tubes, I have the EL38 balloon tubes and the El 11 one a mesh plate, now working to perfection. Seems this silcone tape has helped out in this case, lucked out!![]()
That's fantastic news cf...hope you find this combo as special as I do. But I do realise all ears are different lol!
Just a quickie on another note...it's been a very tiring and intense day!! - remedying a loose connection in what I thought to be just one channel of my T1s (have wired the replacement cable direct to the drivers' connections...tricky!!). And although a couple of the six wires per each earcup had indeed come loose - the bane of using solid wires alas! - it actually turned out not to be the real problem...both drivers were dodgy!!!
Anyway, realising the same connection problem might be in the offing in the other channel, I popped out the driver and...yep, one wire come loose. Not a problem really, as the other 5 were OK. But blow me down, if the same thing doesn't happen while remedying...another dead driver!!
![Triport Sad :triportsad: :triportsad:](https://cdn.head-fi.org/e/headfi/triportsad.gif)
![KSC75 Smile :ksc75smile: :ksc75smile:](https://cdn.head-fi.org/e/headfi/ksc75smile.gif)
And so to try and make things much more secure for the future, I used epoxy resin not just to encase the new wires' soldering, but also those darn tiny driver wires!
![Headphone Smile 2 :smile_phones: :smile_phones:](https://cdn.head-fi.org/e/headfi/smile_phones.gif)
Suffice to say that with a great deal of patience, blood, sweat and tears - plus a good dose of luck! - everything is now working fine once more. And hopefully this time it'll stay that way forever(?!!
For anyone interested in the insides of their headphones, a photo of the tiny wires that just might be lurking therein :
![P1020076.JPG P1020076.JPG](https://cdn.head-fi.org/a/10248978_thumb.jpg)
The offending wires jutting out the top...and the whole driver is only about an inch and a quarter in diameter!!
I know everything must of necessity be miniaturised, but surely, something a bit more substantial wouldn't go amiss lol?!!
![Beyer Smile :beyersmile: :beyersmile:](https://cdn.head-fi.org/e/headfi/beyersmile.png)
