teknorob23
Member of the Trade: Network Acoustics
spot the interloper
Is this normal? There is some pitting and residue between the collar and the glass. It almost looks like some of the base has melted.
spot the interloper
A faulty "over excited" stock power tube, has forced (not massively hard) my hand to roll for the first time while i wait for the replacement to arrive from Poland.
1975 military Mullard 6080 CV2984 from Langrex in Sussex. £30 each and i dont know whether this a good deal or not, but they looked brand new, and after 12 hours run in theres zero noise. I cant give much in terms of compares with the stock tubes SQ-wise until i get the replacements, but i think the bass seems a little fuller.
Does anyone else have experience with these?
Yes, I have long owned a pair, from 1970.
I like them very much, but I do elevate mine via socket savers because the base tends to get quite warm.
Keeping them up, off the deck to helps stave off the heat they gather.
Rich bass, and luscious midrange! Good choice!
Hi t23,thats good to hear, as the choice was more by ever so slightly educated luck than judgement and thank for the tip re socket savers, are the easy to get hold of?
NP with these.Hi t23,
The cheapest source is this one (ask them for a price on two octal socket savers - should be about the same as this offer):
https://www.ebay.com/itm/Bakelite-V...h=item258b9f0bab:g:2-kAAMXQuTNTLSH-:rk:1:pf:0
These socket savers are not super high quality but will get the job done.
There are other offers but they can be much more expensive. You can also make a best offer and shave off some more from the price.
The socket savers save wear and tear on the amplifier sockets, and act as heat insulators which is a good thing with hot running tubes.
